Question about Net10 Motorola W409G Prepaid Camera Phone
How do I use speed dial
Number is programmed in speed dial list but does not work
    Genius:
  • 1,669 Answers
Go on line with Motorola website and download the owner's manual for that phone...all your answers are there!
Posted on Jan 01, 2013
How do I change the speed dial keys that are already programmed?
  1. In the phone, press the Menu key.
  2. Click View Speed Dial List.
  3. Click a contact or phone number.
  4. Perform one of the following actions:
    • To change the contact that is assigned to a speed dial key, click Edit. Click a new contact.
    • To assign the contact to a different speed dial key, click Move. Roll the trackball to move the contact to the new speed dial key. Click the trackball.
    • To delete the contact from the speed dial list, click Delete.
Jul 07, 2014 | Mitel Superset 4015 Corded Phone
KX-Ta824 Speed dialing problem
Panisonictel.com has a FAQ for this model here
In that FAQ, there is this explanation of your problem:
When I tried to access speed dial, it does not call out.
When storing speed dial number of external parties, the stored speed dial number must include CO (outside line) access code (9 or 81…etc) even with direct line access. If the external number is 1234567, you must store the speed dial number as 91234567.
This rule applies to all system speed dial, station speed dial and speed dial key.
It looks like you're just going to have to add a leading 9 to all the speed dial numbers for that function to work.
Nov 04, 2007 | Panasonic KX-TA824PK Phone
Speed dial does not work
Look at the number that is in there for the person you are trying to speed dial,your voice mail is always #1.To use speed dial you just use the number the person you are trying to speed dial lets say they are in your phone as #2,hold down the # 2 on your keypad for around 3 seconds and it should start dialing.
Jan 01, 2013 | Net10 Motorola W409G Prepaid Camera Phone
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
How to program speed dial for various customers
1) To program a personal speed dial number, leave the handset on-hook. Press ALM/SD followed by the DSS button where you want to store the number. Dial the telephone number to save, up to 30 digits (press HOLD to insert a 3-second pause or MSG in insert a hookflash). Press ALM/SD to store the number.
2) To dial a speed dial number, select an outside line. Press the ALM/SD button. Dial the desired speed dial code 10-98 (system speed dial) OR press the desired speed dial button on your phone (personal speed dial).
3) System speed dial numbers may only be programmed by the system administrator.
Jun 02, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
How do I programm the Speed Dial on my 4406D+?
To program your Personal Speed Dial numbers, make a list of
your telephone numbers/extensions numbered 1 to 24, then:
Press an Intercom button + lift handset + dial #00 + dial # + list number (01 to 24) + dial *21 + the number you want to store + #*00.
To use Personal Speed Dial:
1: Press an Intercon button.
2: Press Feature (if you have programmed a "Feature" button) or #.
3: Dial the two-digit code (01 to 24).
Apr 27, 2010 | Avaya Merlin Magix 4406D+ Corded Phone
I programmed a speed dial number, how to I dial
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Oct 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Trying to change a fax number in memory
To change info:
"user tools" (ok)
"fax features" (ok)
"general settings /Adjust" (ok)
"program fax info" (ok)
...then set name, number, etc.
"user tools" to exit
To print speed dials:
"user tools " (ok)
"fax features" (ok)
"reports / lists" (ok)
"dial list" (ok)
"Quick dial list" or "speed dial list", etc (ok)
I hope I'm your Hero now :)
Please rate me.
Apr 01, 2009 | Ricoh Aficio 1013F Copier
Vu 204..new phone, speed dial does not work, goes to verizon wireless message which says call cannot be completed as dialed. Checked numbers they are OK, also happens which #1 for speed dial of *86 which...
I had the same problem and found that the speed dial feature in "settings" is not turned on by default even though voice mail number is pre-programed into the speed speed list. Go to "Settings & Tools/Call Settings/One Touch Dial" and turn the option on.
Cheers,
Don Devine
Mar 30, 2009 | Motorola Mobility VU204 Cell Phone
Net10 Motorola W409G Prepaid Camera Phone Logo
49 people viewed this question
Top Net10 Video Cameras Experts
Are you a Net10 Video Camera Expert? Answer questions, earn points and help others
