Question about Logitech Labtec WebCam 961307
Labtec webcam no effects or animations
Labtec webcam has no effects or animations for instance you want to go live cam with a mate on msn and want to have a laugh you just cant because theres nothing
    Scholar:
  • 33 Answers
Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
Posted on Aug 06, 2009
    President:
  • 8,637 Answers
See section C. Windows Live Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Posted on Aug 25, 2009
    Problem Solver:
  • 15 Answers
You need to buy or get effects usually unless your video cam is built in
Posted on May 31, 2009
How do you get your cam to work on msn
Ensure the cam works off line in the PC, go into MSN properties and enable web cam. Make sure web cam properties match your cam.
Dec 20, 2009 | Labtec Webcam Pro
How to get labtec webcam to work on msn live?
We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again.
this is the error msn i get when iam trying to use my camera in msn messenger on all other i can use ? whats the reason ?
Oct 09, 2009 | Xirlink Promax Webcam
Im having trouble stting up my web cam with msn
Well, i think you're using some security software such as mcfee or kis or avg. You should go to the window firewall and then you can check it for window live messenger. and then you can enjoy it!
Feb 03, 2009 | Labtec 961307-0914 Webcam
Labtech usb web cam
open up msn to a full page and click on web cam settings and select your cam and WORKS whoop whoop !!
Dec 31, 2008 | Labtec 961307-0914 Webcam
My cam (labtec)
oh wait.. the camera is just black when you view it?
Jun 03, 2008 | Labtec Webcam Plus 0403
Labtec webcam
hi jodieheart this is nichu,
donot worry if you have dont have the disc ,you can download the necessary software for your labtec webcam in this website, http://www.labtec.com/index.cfm/service/listing/AMR/EN,crid=68,crid2=1764
select the type of your operating system and chose the language,and then click on download start working with your webcam.stay cool.
bye,
take care & have a nice day
Nov 07, 2007 | Labtec 961307-0914 Webcam
Can't transmit video via MSN Messenger
As long as she is accepting your call when invited it should show up a little MSN advert then show your picture. The problem may be at your end, so check that you have the cam set up in settings and you both allow video to be accepted, ckeck all the web cam settings and menu options. If you haven't already, download MSN live messenger.
Mar 07, 2007 | Labtec Webcam Pro
Webcam and Live Messenger
I can use the webcam on Skype but when I close Skype and open Instant Messenger I get a message that the webcam is unplugged or being used by another application.
Oct 28, 2006 | Labtec 961307-0914 Webcam
Logitech Labtec WebCam 961307 Logo
312 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
