Question about Coffee Makers & Espresso Machines
Learning how to use the krups FND1 espresso machine
Good afternoon. I just purchased a krups FND1 espresso machine. Since I have never made a latte or capaccino myself, I have no idea as to how to do this correctly. I did receive the written instructions, but would rather have some type of instructional video or step by step instructions with photos. I have been looking online for quite some time no to no avail. Can you please help me? Thank you.
We have problem with coffee machine faema presidentE98 2 group, the problem is motor pump is still running, water boiler is full can't stop or cut off power to motor pump? so what solution ? thank's ,
junaedi
Posted on Jul 27, 2010
Krups FND1 lid pressure release spring and seat came apart. How do I reassemble the safety release?
The lid is broken, you need a new lid. I have checked online and it is available, part number is MS 0927155. There will be small plastic pieces in the boiler, fill it up and tip it upside down & shake it about.
Jan 13, 2015 | Krups Coffee Makers & Espresso Machines
Krups ea 80
Good afternoon... On my krups machine and failure code appeared 8025 09. Said It was the temperature probe. I'd like to get a picture of the temperature probe and its cost. With the best regards
Joao Araujo
Feb 16, 2014 | Krups Small Appliances Espresso Machine
I have a new Krups XP 5240 machine. The instructions tell you how to make espresso and froth milk for cafe lattes, but don't mention how to actually MAKE the latte. What is the correct procedure for...
A latte can be made to suit your own taste, but as a starting point I would suggest:
Steam your milk first to 140 f, let it rest for at least 30 seconds( the temp will continue to rise up to around 160-180 f
while the milk is resting make your espresso shots; I like quite a strong coffee so I would make 2 shots using the double measure (once the coffee starts flowing this should take 15 seconds)
pour your shot(s) into a cup/mug first then top up to about 5mm from the rim of the cup with milk, holding the froth back with a spoon.
finally knock out any bubbles by banging the milk jug on the worktop ( this can be messy until you get good at it). using a spoon/ swirling the jug mix the foam and remaining milk until combined then top up your cup. this gives the smooth foam on the top of the latte.
Hope this helps,
Leni
Nov 06, 2010 | Krups Cappuccino/Espresso Maker -...
KRUPS FND1 HOUSEHOLD ESPRESSO MAKER MANUALS
There are similar manuals here, maybe they will be helpful for the model that you are looking for - http://kitchen.manualsonline.com/manuals/mfg/krups/krups_coffee_grinder_product_list.html
Jan 31, 2010 | Krups Allegro FND111 Espresso & Coffee...
I just recieved a krups fnd1 used..do i have all parts
You should have the main machine, the screw-top to the main machine, a handled cup that holds the grounds, and inside that should have a metal lining. Drain basin. Main body should have: Screw top, turn-switch, milk foamer attached.
Aug 29, 2009 | Krups Allegro FND111 Espresso & Coffee...
Need a manual instruction for Krups Allegro Espresso FND1
Go to krupsusa.com and click on "instructions" they have it there
Jun 08, 2009 | Krups Allegro FND111 Espresso & Coffee...
Can I get an instruction manual for KRUPS FND111
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={706F793F-3236-4CA4-B5BA-C414DF982294}&SelectedProdRef=FND1
From the Krups website.
Apr 06, 2009 | Krups Allegro FND111 Espresso & Coffee...
Hi, we have a Krups espresso machine, model fnd1. We can't seem to make the milk steamer work, it will make the milk REALLY hot, but not foamy. Do you replenish the steam supply somewhere? Is there a...
suggestions include very cold milk.  having the nozzle just barely in for frothing.
On my model there's an air passage in the nozzle that foams quite nicely.  If you have that too, it might be clogged with milk.  You have to keep these clean with every use.
Jul 11, 2008 | Krups XP4030 Espresso Machine
Krups FND1 water escape
What position do you have the knob in? According to your manul it should be in position 9 not in position 8 for steaming.Good Luck.
Apr 11, 2008 | Coffee Makers & Espresso Machines
Espresso maker
gose to : http://www.krupsusa.com/NR/rdonlyres/6907301C-7474-4ECF-857D-650657C83A4C/7923/FND1.pdf
Jun 17, 2007 | Krups Allegro FND111 Espresso & Coffee...
Coffee Makers & Espresso Machines Logo
696 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
