Question about Kenmore 82822 Electric Dryer
I have a kenmore elite he3 dyer it does everything it is supposed to but heat. pulled the front cover off unpluged the dyer and cleaned the inside, started the dryer again and the heating element came on for a few min then shut off and never came back on. Does this mean it is my thermostat?
  • 3 Answers
A possible fix, which sounds completely absurd is to reset the circuit breaker. If you visually examine the breaker it will not appear to net resetting. This is because only half the breaker has been blown. You will not see this visibly and my husband thought I lost my mind and spent several hours troubleshooting before he would listen to my solution. We have only had to do this once in the six years of ownership. Hope this helps
Posted on Jan 29, 2009
My mom's Kenmore HE3 Elite electric dryer vibrates rapidly while operating. She was cleaning out the lint catcher area with a toothbrush and dropped it inside, then decided to run it after several failed...
yes u have to now replace the blower fan housing u may be able to take apart and remove broken piece byt may not run properly or circulate heat and air as it suppose to
Mar 22, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 Dryer not heating
check the thermal fuse and also check to make sure you have 220v at the outlet.
Jul 23, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite HE3 gas dryer does not heat up? What do I do?
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this is fine then you’ll need to check the thermostat, igniter and coils. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite dryer runs cold no heat
Most of the time its the thermal fuse part # 3390719
Jul 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Drum turns...no heat
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
Apr 19, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore front load He3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite He3 electrical dryer runs but it does not heat up
odd but it worked for me!! Try resetting the circuit breaker. It will not appear to have blown, this is because only 1/2 the breaker needs resetting, This is much cheaper to try before calling for service or parts. My 2002 E3t has only had this problem once and the resetting worked without further issues for 2 years now. Good luck
Dec 12, 2008 | Kenmore 82822 Electric Dryer
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 82822 Electric Dryer Logo
198 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
