Turned on with remote will not turn off neither with remote or on/off switch on unit
The main board needs replacement. Yoiu can get the main board from www.tvrepairworld.com
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: UVERSE REMOTE CAN NOT TURN OFF VIZIO 42' TV
The documentation that came with my U-Verse equipment doesn't list Vizio products, but I have been using 1343 which I saw suggested on another website. AT&T's support site has a new code list (http://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf) showing Vizio under the TV section as 1489 and in the HDTV section as 1429, 1433, or 1439.
None of the codes listed for Vizio work with my Vizio LCD(model VO370M), but the 1343 code I've been using successfully is listed in the new list as an LG HDTV code.
