Question about Jenn-Air 22 cu. ft. Expressions Collection Side-by-Side Refrigerator JCD2289AT
Jenn-air refrigerator model JCD2289AT not cooling or making ice
THE FREEZER IS NOT MAKING ICE AND THINGS WERE THAWING OUT. WE LOWERED THE TEMPERATURE OF THE FREEZER. IT IS NOW COLD IN THERE BUT STILL NO ICE AND NOW THE REFRIGERATOR SIED IS NOT COLD.
SOURCE: Increasing ice AND temperature paradox
After reading this forum and other places I was pretty sure that luck of defrosting is a symptom and the defrosting timer relay is the most likely problem in my case. I must say that my Jenn-Air JCD2289AT refrigerator was occasionally creating rattling sounds in the upper right corner under the panel. I suspected some relay malfunction. This sound lasted for almost a year and then stopped. Refrigerator lost the temperature while working continuously without turning off. I went to a local parts shop and they had this defrost timer in stock. They said that the item is very popular and they always keep it in their stock. Calling technician would cost me $80 and the part was also $80 (not returnable). I’ve made my best bet and bought the part. I removed the panel and found the timer small board (2x3 in) in the upper right side. Make sure unplug refrigerator from power before changing it. The new part is coming in a plastic case, while the old part was without a case. I removed the cover to take picture and compare. My old part had a relay with a bulge on a side apparently due to burned contacts inside (see photo),
cbf6fab.jpg while the relay on the new one was perfectly square.
c49b9ad.jpg This is a picture without a cover.
I turned on the refrigerator and didn’t see any difference. Obviously, it needs defrosting. I was afraid that automated defrosting at a random time would flood my kitchen, so I opened up the panel in the freezer part to expose coils. Here I took an opportunity to check heating element with a relay. The relay was in “on” position, as supposed to while immersed into ice. The heater showed a resistance of 22.6 ω, and I thought it was OK.
e207d3c.jpg This is partially thawed situation (I used a hair drier).
On the bottom left of the compartment I discovered a 2x3 inch opening connecting the freezer and refrigerator compartments. It was initially completely clogged with ice. That’s why the temperature in refrigerator part was so high, while the freezer stayed cold.
05b8f22.jpg This is a veiw from refrigerator compartment. The hole is ~ 6 inches above the bottom on the left side. It provides cold air from the freezer compartment. If I checked it first, it would give me a clear idea what was going on.
7aee4b8.jpg I tried to collect water as much as possible not to overfill the tray under refrigerator.
Still the water spilled onto the floor. I pushed down on the front side of the tray and made a controlled spill. Now the tray had extra room for any residual water.
Refrigerator is working normally now.
This was the second strike. I am planning to move it to the garage and buy another brand. I think Jenn-Air/Maytag engineers are not smart enough to use old fashion electromagnetic relays. Technology offer more reliable electronic switches now for at leas several decades.
Happy end
Posted on Aug 19, 2008
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Posted on Feb 13, 2010
SOURCE: Jenn-Air fridge not cooling
Yes, the problem is most likely with the
"ADAPTIVE DEFROST ENCL.
61005988.
I just watched my repair guy fix our fridge with this same problem ($232.75 later). What is happening, is that the freezer coil no longer defrost itself. Cold air cannot then blow into the refrigerator side anymore. To fix, remove cover at the bottom of the freezer and manually defrost the coils with warm water ... use bath towels at bottom of freezer to soak up the water. Replace the cover and then go to the refrigerator side. Remove the plastic cover at the top of the compartment to access ("ADAPTIVE DEFROST ENCL. 61005988).. This is a small plastic box measuring 3 1/8" x 3 3/4".
Simply un-plug the wires, and plug- in the new unit, then re-assemble with just a few screws. The retail cost of the part is $92 from the appliance guy, but you can probably find it on the net far cheaper.It's a really easy job that can be done by anyone slightly handy ...and you will probably save yourself at least $100 in the process. The next time this happens, I know what to do. It shouldn't take more than 1/2 hour for the whole process. If you mess up (which I'm pretty sure you won't) you should save some dis-assembly labor for your technician and some $ in the process. It's really easy to fix!
Posted on Jun 28, 2010
woodchuck789
  • 4059 Answers
SOURCE: Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on Jul 13, 2010
Jenn-Air JFC2089HES ice maker
Try letting it thaw out and re start it.
Jun 19, 2014 | Jenn-Air Refrigerators
Jcb 2059 ges Jen air fridge part not cooling freezer o.k.
If freezer cooling but fridge not cooling,then its a defrost issue.First freezer cools,then cool air from freezer gets to fridge and fridge gets cool.But if freezer defrost cycle not taking place then its faulty defrost assembly parts.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Jenn-Air JCB2059G Bottom Freezer...
Refrigerators Problem
Make sure coils on back of unit are clean and not touching wall. Are doors closing and sealing with magnetic strip fully? Has some one changed settings without you knowing?
Dec 04, 2011 | Jenn-Air Refrigerators
First the refrigerator portion lost cooling but the freezer was fine over time the freezer esentially turned into a refrigerator. It is no longer making ice or keeping things frozen, but is about as cool...
the evaporator coil is frozen over and cant release cold air due to this,defrost the unit remove rear panel inside freezer and troubleshoot the defrost heater and thermostat and also make sure the fan near this coil is running, on the evaporator coil as,you cant blow cold air thru a coil covered by ice
Jul 02, 2011 | Jenn-Air JSD2789GES Side by Side...
The ice maker is not making any ice
Hi rlh2004,
There are several factors why a refrigerator tops making ice. We will look on the most common factors and give you some troubleshooting that you can do to fix the issue.Before doing any checking or repair please unplug the refrigerator, remember your safety.
1. Check the shut-off arm - An arm extends away from the ice maker over the ice cube bin. During each ice making cycle, the arm rises up and then drops back down after the new ice is dumped into the ice cube bin. For proper operation, confirm that arm is in the lowered position and that nothing is blocking it from normal movement.
The arm is supported at one or both ends. One end extends into the back of the front support. If it is not securely in place, it could cause the ice maker to malfunction. Confirm that the arm is securely in place. To test the shutoff function, lift the arm up into the manual shutoff position. Recheck the unit later to confirm that no ice is being made.
2. Check the water supply line - The water supply line connects to a supply valve usually found under the kitchen sink or behind the freezer. If the valve is not turned to a position which allows for enough pressure, the water may not fill the ice mold.
Check that the water valve is opened to allow enough water to fill the ice mold. You can open the valve all the way but it is better if you open it just enough to provide the adequate pressure level.
You can also inspect the water supply line for dents or pinching that might restrict the flow of water to the icemaker.
3. Check the freezer temperature - The ideal temperature for the freezer is about 5 degrees (F). The refrigerator should be kept at about 36 degrees (F). The temperature can be adjusted using the controls found inside the freezer or refrigerator.
Hope it helps.
Thank you for using Fixya.
May 03, 2011 | Jenn-Air JFC2087HRS Side by Side...
The ice maker does not stop making ice when the bin is full
dear sir/madam
please make sure first your freezer,s defrost mode selecter set on auto mode or it,s set on auto defrosting mode. if it.s or freezer making continuously ice in ice bin then defrosting control device or temperature controller is not working for repair it please contact to your maintenance personnel for replace it .i hope after that it will work properly.
hope answer the question
thank you
please vote!
Aug 24, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Ice maker freezes Whirlpool gold
try to remove all the ice in the bucket first and start all over again. the first bundle of ice could be the one making the problem. and then check the cold air vent towards the ice bucket. there should be cold air blowing to it to maintain the temperature in order for the ice not to melt.
after removing all the ice and inspecting if there is cool air coming out towards the ice bucket. let it run and observe it.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerators Logo
67 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
