Question about Dell 1110 Laser Printer
How can I un jam a paper jan in Dell 1720 laser printer?
The paper is stuck up in the back of the printer. I could see a little of it when I took the front off and paper tray out. Thanks, Helen
    Master:
  • 461 Answers
Open the front cover and remove the toner cartridge to see if you can access the paper, if not open the top and inner cover to locate the paper and gently pull it out.
Posted on Jan 19, 2009
Paper jam C1660w - there is no paper jam! It's been cleared but the machine won't reset and is useless.
I had this happen to me twice (bought a new replacement Dell 1660W when it happened the first time) before I figured this out: The error message states to open the back cover but I did not find a problem there. Took a flashlight and looked inside the opening at the TOP of the printer where the paper normally comes out. There was tiny piece of paper that was stuck inside there. Removed it with tweezers and the problem was solved (for both printers).
Aug 09, 2013 | Dell 5V05D C1660w Clr Laser Printer 12 /...
Dell 1720 DN- all lights flashing- please advise
try to turn off the printer, remove the power cord, then press the power button for about 5 secs. plug it back, turn it on. If same thing, press the cancel button for about 10 secs. if still the same, try to check the cartridges, remove them and make sure they are not yet empty, shake them a few times, then connect them back. Make sure no paper jam as well.
Aug 30, 2010 | Dell 1720dn Laser Printer
Dell 1720 laser printer shows paper jam after clearing jam and turning off and back on.
some paper piece may be left in the printer.
Please check where was the leading edge of the paper when it was jammed. some sensors may have got stuck while removing paper. open the toner door remove the toner cartridge, just see all the sensor flags with fingers, refix toner and power on and try printing
Dec 01, 2009 | Dell 1720dn Laser Printer
Paper jammed (Dell lase Printer 1720dn
Open the back cover and look for paper wrapped around a roller back there. That is the most common cause of the issues with this machine. The other thing you can try is to push down on the little flaps where the paper comes out of the printer. These get stuck and need cleaning/replacement all the time in the later life of these models (1720's).
Jul 28, 2009 | Dell 1720dn Laser Printer
1720 printer clicking and will not pick up paper
open the back "flap" up, and locate the pick up rollers. if the roller is jammed or stuck, just rotate it manually until it begins to pick up paper again
Apr 09, 2009 | Dell 1720dn Laser Printer
Yellow light on and won't print on Dell model 1110 Lazer Printer
Dell printers are the worst I have worked with, this problem may be a 'paper jam' when there is no paper jam at all (or one REALLY stuck on the fuser). Check on the back of the printer for a piece of paper jammed on a sensor.
Dec 14, 2008 | Dell 1110 Laser Printer
Paper jam
There is a sensor in the back that lets the printer know the paper has exited the fuser. It is probably broken off if paper is getting stuck back there.
Also check for paper remnants that are jammed. This may require removal of the fuser.
Mar 13, 2008 | Dell 1700n Laser Printer
Media Jam- Fuser
thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Oct 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
My dell 1700n Laser Printer Paper Jam Light stays on
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Aug 29, 2007 | Dell 1700n Laser Printer
Dell 1110 Laser Printer Logo
365 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
