I have a IRULU 8gb mp3 player and I connect it to my usb connection and my computer doesn't recognize it and doesn't show that it is connected.
  • 6 Answers
SOURCE: won't recognize connection
proper software is not installed
contact your vendor for proper update
Posted on Jan 07, 2008
SOURCE: device unrecognizable on computer
if you are using windows 98se you need to load driver from disc.if you are using xp it should load up stright away i had no problems with xp and mp3 player
Posted on Jan 18, 2008
SOURCE: Sylvania SMPK 1021/2021 MP3 Player
You have bought a piece of 3rd party ****. They will not sign the driver they will not develop the driver, they will not release the source code. Your best bet at this point is to ask the linux community for help or return the device.
Posted on Jan 11, 2009
SmartAviator
  • 449 Answers
SOURCE: When USB is connect MP3 player does not display all songs
Try running scandisk, chkdsk or simila program or format it using FAT option.
Posted on Jul 20, 2009
  • 8 Answers
SOURCE: No pc recognizes the V-touch 8gb mp3 player by Visual Land
Windows xp, Vista, and Windows7 should already have a driver included for the v-touch. It's possible that if your computer has a compact flash card reader, that it maybe preventing the v-touch driver from being correctly installed. Try using the "Safely remove Hardware" to temporarily remove your cf card reader. Then try plugging in your v-touch. It should now correctly install the driver and the v-touch will show up as a new drive. In Windows Device Manager under "Disk Drives" you should see 2 new devices - "Company PNP Platform OPN USB Device" and "Company PNP Platform SDC USB Device
Posted on Dec 23, 2009
When I connect MP3 player to laptop via USB cable, it does not show up in removeable devices. Laptop does not recognize it. Worked previously. Please help.
is it powerd on? some devices need to be on before the computer can recognize it like my digital camera has to be on before i can use it via the USB cable
Jan 16, 2016 | Eclipse Fit Clip Plus 8GB* MP3 Player
Tip
Connecting an Eclipse MP3 Player to a Computer
Many people have found that their computers do not recognize the Eclipse mp3 Player, even after connecting with a USB cable. I had the same problem but discovered that the problem lies with the cables themselves. I have several USB 2.0 5-position cables that fit the Eclipse USB port perfectly, but only ONE of them actually works - the cable that came with the player itself. If you've lost this cable, you may be in trouble.
Attached is a screen-grab of the type of USB plug and port involved. You don't see them around very much anymore, and I have no further advice if your player doesn't have a USB port of this shape.
on Feb 01, 2015 | Eclipse Audio Players & Recorders
Computer doesn't recognize my icoustic mp3 player
replace the usb connector then tried to hooked up to the other usb port.
Jul 10, 2012 | Audio Players & Recorders
When I connect my mp3 player to the computer, the computer does not show me that it is connected. I have tried other devices, and they connect properly. I am trying to download songs from my music files to...
>Ensure that the player's memory capacity is not full.
>Ensure that the Hold switch is disengaged;
Reset the player >
Use a paper clip to gently press the Reset button on the rear of the player.
Try connecting the player to another usb port on the computer to see if it is recognized ,or try
using another USB cable.
Try connecting the player to another computer..to see if it is recognized
Aug 01, 2011 | Coby MP826 MP3 Player
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
My computer is not recognizing the coby MP815-8GB and saying that it is corrupt. Please suggest me how to fix this problem?
On the MP3 player itself, go to Setup > System > put the USB mode to MSC.
Reconnect the MP3 player to your computer, it should appear as a 'Removable Disk' drive under 'My Computer'.
If that doesn't resolve and you still get the 'USB Device is corrupt', try replacing the USB cable.
Jun 28, 2011 | Coby MP815 Digital Media Player
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Dec 21, 2010 | Sony Walkman NWZ-E344 Digital Media Player
Sansa Fuze, 8GB, unable to be turned on in the car after playing it just a short while ago, and is unable to connect to computer; screen is white.
You may need to now reset the player, that may have been a bit much for it. To reset your Sansa Mp3 player. Slide and hold the Power switch up for approximately 20 seconds. Release the Power switch. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present.
http://www.fixya.com/support/r3962743-sansa_mp3_player_frozen_reset_format
-Also try to refresh the driver in your PC. Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. >>>><<<Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
Usb is not recognizing sansa
try going to "my computer" on your desktop and it should show an unkown device thats plugged into one of your drives
Aug 01, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
71 people viewed this question
 Grubhead
Grubhead
