Samsung b1445a door interlock burnt out
Hi, I've been suffering from what seems a really common problem with my samsung washing machine - a de error. It's got to the situation now where I can't use my washer, it stopped mid cycle and now won't recognise the door being closed so won't work at all. Thanks to your site I've successfully located and removed the interlock, but to my frustration the spade connector that plugs into it has burnt out and melted. So whilst I can find a interlock switch and could easily fit that the actual spade connector from the wiring loom also needs replacing but I can't find that online to order and fit. Is this because it may be soldered on so may not be a job for a non-professional? Any help / advice would be gratefully received. Thanks!
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
Even if it is soldered on, if you feel confident you can desolder it off with a soldering gun! Then you could go to a good hardware store and get the size spade lug you need and solder the new one on!
Posted on Jan 01, 2013
4 Suggested Answers
SOURCE: Hotpoint WM83 control module plug connections
Fixed it - by a process of elimination and logic :) What was worrying me initially was the fact that it is possible to fit the connectors in either position (Hotpoint!).
Posted on Jul 04, 2008
  • 75 Answers
SOURCE: i have a hotpoint few12 washing machine and have
hi
check the spring on the door handle/catch,the easiest way to check this if you close the door and it indicates that the door hasnt locked,push the inner part of the handle towards the machine,if it locks then the spring is worn.(this is more commen than the interlock).
Posted on Aug 05, 2009
SOURCE: The door interlock on my samsung washing machine
I am having the same problem. Did you find an answer to this?
Posted on Oct 16, 2011
What does DE error indicate?
DE indicates "Door error" The door isn't closed properley or the door interlock mechanism is failing. Samsung and LG machines do occasionally have an issue with the door interlock connector coming adrift from the lock mechanism. Unfortunately it's as likely to be a faulty lock or a problem with the main controller
Dec 26, 2015 | Samsung Washing Machines
What does dE mean on the samsung sw5asp top loader washing machine
dE means the door its detected as closed
a quick look at THE USER MANUAL
tells you the error codes
http://downloadcenter.samsung.com/content/UM/201409/20140922144717463/WD8704RJ-02718A-07_EN_XEU.pdf
here is the link
if the door closes firm
then you get the DE error then the door interlock has failed
and will need to be replaced
Feb 07, 2015 | Samsung Washing Machines
How to open the door manually for samsung WF9904CWN
Hi David.
If the door is locked and won't open, it's probably because the 'Interlock' has failed.
The Interlock is the part of the door lock which prevents you opening the door while the machine is going. It's part of the electrical circuit and should only be replaced by a technician..
Good luck
Nomess
Feb 04, 2015 | Samsung Washing Machines
HI! I HAVE A MESSAGE ON MY HOTPOINT WMF760P WASHING MACHINE OF ' DOOR ' COMING UP & IT'S STOPPING SHORT OF THE WASH CYCLE & THEN YOU CAN HEAR THE LOCK MECHANISM
http://www.ebay.co.uk/itm/HOTPOINT-WMD9692-WMF520-WMF540-WMF560-WMF720-WMF740-DOOR-INTERLOCK-SWITCH-/390558604486?pt=UK_Irons_Presses&hash=item5aef1b5cc6
you need one of these
take the lid off and open the door
isolate the mains supply and water supply
remove the two screws that secure the interlock
this is what the doors catch sits in
reach down and tilt slide it out
remove the plug
plug in the new one
and remount
screw back in the two screws hand tight avoid stripping the plastic
and return the lid in position
now reconnect the water and mains and test
the door closes and the machine should now work aok
did one the other day
Dec 08, 2014 | Hotpoint Washing Machines
The door on my Samsung Washer won't latch. It then displays DS error. Seems the roller in latch is down therefore not allowing door to close all the way.
This means your door interlock has broken & needs to be replaced.There made of plastic this is a very common problem with all brands of front load washer's.
Mar 13, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
I have a front loader Samsung washing machine. JI045AV. The cycle has finished and the door will not open. Have tryed putting it through another cycle, turning power on/off and trying different settings,...
Your door interlock has failed & needs to be replaced.Usually the computer should come up with error code DE error,& if your machine's main p.c.b/computer may have been taken out also,If this is the case it will need to be rewired to fix the problem,hopefully it is just the door lock if not it may cost up to $500 dollars to repair.GOOD LUCK.
ECO KIZZA.
Feb 24, 2011 | Samsung Washing Machines
Front loader iwll not start DE error code Samsung model J1045
this means door error sometimes you have to rewire it, replace the computer & the door interlock all at the same time to fix it try the door interlock first beware sometimes if you dont do it all at once the new part gets taken out as well so fingers crossed its just the door interlock.best option to have samsung service agent out to check out with diagnostic tools.
Jan 13, 2011 | Samsung WF337AA Front Load Washer
My samsung washing machine indicates the door is open yet its closed whats wrong
the door switch is broken or a wire has come off take the switch unit out and check its connected then check it to see that its working if you dont know how to take it to a service shop they should test it for free and tell you if it needs to be replaced then you can order one from your nearest samsung auth repairer.
hope this helps
merry christmas
please rember to rate this advice thanks
Dec 07, 2010 | Samsung WF337AA Front Load Washer
Samsung b1445a (5E) fails to drain. Cleaned debris from filter. No damage to drainage hose.
SAMSUNG B1445A. de FAULT.
This is a problem with the door. Its 14 months old within a 2 year warranty, but because Comet took so long to sell it to me and there is a time lag between manufacture date and sale, they will not honour the warranty, unless I can provide a delivery note. I collected it myself. Thanks Samsung. I will never buy another product with your name on it again.
Thats ok. The problem is the door. It closes ok, but the washing machine doesn't think the door is closed. I think there may be a sensor on the door. Anyone know what the part no. is, and how to get at it to either clean or replace it.
Help would be much appreciated, as 30 minutes giving my personal details to a person in a call centre who speaks like an Amercian robot, has done nothing but irritate me.
Dec 03, 2010 | Samsung Washing Machines
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
