Question about Air Tools & Compressors
Need 57-7900-2 brad nailer - Air Tools & Compressors
  • 65 Answers
SOURCE: brad nailer does not retract enough for brads to enter nailer
hi check to see if there is any wear on the blade or even if it is broken if so replace with a new item from your dealer , this will also come with a new seal so with a good clean your gun should bee like new hope this helps ian
Posted on Mar 25, 2009
sawdust46694
  • 398 Answers
SOURCE: I need a manuall for a BT200 Brad nailer
http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=tooldoc.htm&LEFT=left_tooldoc.htm
here you go. Hope this will help you, Sawdust46
Posted on Aug 09, 2009
  • 74 Answers
SOURCE: porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Posted on Aug 29, 2009
Testimonial: "Thanks for the info. I was not oiling it at that rate. Is there anything I can do to fix the issue now that I didn't prevent it?"
  • 10865 Answers
SOURCE: need a manual for craftsman 18 ga comb
go to sears.com where all of these manuals are found in downloadable form.
Posted on Oct 29, 2009
  • 142 Answers
SOURCE: My brad nailer shoots staples without any problem
the only suggestion i have is that you may have a feed problem, so i would clean and lube the track the nails run on
Posted on Mar 27, 2010
I have NT32Ae2 brad nailer. It worked fine when first used it 2 yrs ago. It now will not pink up brads but the gun will fire. No problem with compressor. The driver will come down and mark the wood.
Make sure your using the right gauge brads for your gun, should have sticker on rail with required brad gauge, and max length. Sometimes a brad will get jammed under drive pin where you cant see, might have to remove allen screws over pin to get jammed brad out
Oct 24, 2013 | Hitachi NT32AE2 58to114Inch by 18Gauge...
Brad nails crooked in bostitch
Have you inserted the correct Brad Nails? What is the code of brads you have inserted? Is the tool jammed?
Solent Products Air Nailing and Stapling Supplies
Mar 21, 2013 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
My Task Force electric brad nailer is jammed.
Brad nailers typically jam for one of two reasons, a misaligned or bent brad on the brad strip or a defect in the brad strip itself. Remove the brad strip in the nailer and replace with a new one. Examine the striker head first for any signs of residue keft from the jammed strip.
Oct 31, 2010 | Garden
Does the brad nailer only use 2" brads or cam smaller nails be used also
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
How to remove brads jammed in the nailer
Open the top where the plunger is...remove the jam and push the plunger back..close up the gun and you should be fine. Make sure you disconnect your air hose first!!!
May 09, 2010 | Tools & Hardware - Others
18 ga. Bostitch nailer that has a small brad jammed in it.
check your hex wrenches they could be standard when they need to be metric.
Sep 23, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Porter cable brad nailer only fires brad on second trigger pull
Aug 29, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
