Question about Garden
The rope jerks back through my fingers when i try to start it. and it hurts
    New Friend:
  • 30 Answers
Hang on tighter.
Posted on Jan 01, 2013
How do I cure kickback when starting a Stihl 044 chain saw , as soon as you pull the starter cord it snatches it out of your hand it really hurts.
pull rope just pass compression piston top dead center release rope let it rewind fully .then pull rope quick and firm.
Oct 10, 2017 | Stihl Garden
When I try to start the tiller (9hp Honda) the rope will kick back hard jerking it out of my hand
Ed. the key way on the shaft to flywheel could be sheered throwing timing way off, which does this kick back.
Feb 21, 2016 | Husqvarna PRRT850X 960920015 CA 17" Rear...
When trying to start the starter rope jerks back
did you try removing the air filter and see if it does the same thing?
Nov 27, 2015 | Garden
When try starting the pull rope jerks back
did you try removing the air filter to see if it does the same thing? Make sure there is oil in it also.
Husky power washer 2600 Tried fixing starter
I'll send you a link to a great video of how to recoil a starter spring, so you wont lose and fingers or eyes. :)
Aug 01, 2013 | Garden
Hit steel rod. bent blade. replaced blade, runs but vibrates,bad. and when you try to start it the pull cord, jerks your hand back
probably sheered fly wheel key also check to make sure crank shaft is not bent. lay mower on side air cleaner up remove spark plug wire have some one watch blade bolt while u pull rope bolt should turn with out wobble.
Aug 12, 2010 | Garden
How to assemble pull cord
Remove engine cover. Try turning the inside where rope goes counterclock wise then let go (watch your fingers so you don't get pinched. If it spins back remove the rope and and turn the inside till you get some good tension. Put a screw driver through the fins to hold the inside in place so it doesn't unwind. Make sure you line up the hole in the inside so the rope will go straigh through the hole on the shroud and the inside wheel. Tie off the rope and hold the rope and remove the screw driver and slowly let rope back in. Pull a few times to check before reinstalling. Also check the inside wheel. There should be in the center of the wheel a bolt that holds on a flat piece of plastic and under that directly across from each other is two little tabs that engage the fly wheel. Make sure they are both properly seated. If it recoils when you test it reinstall and try starting mower.
Good luck and let me know if this helps
roundo4
Aug 13, 2009 | Mtd Garden
Engine is jerking when ac starts
rpm should go up when A/C turned on ,the control for that is built in to the engine management system,sorry back hurting sitting at computer ,take to dealers for the computer to be checked ,might just be something simple
Jan 18, 2009 | 1996 Toyota Camry
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
