Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
Sound from the hard drives when booting
It slows down the computer
  • 716 Answers
You Need To Defrag The Hard Drive. Go To Start, All Programs, Accessories, System Tools, Disk Defragmenter Then Click Defragment This Should Be Ran On All The Available Hard Drives.
Posted on Jan 18, 2009
Why does it take my computer a long time to boot up, loading, and shutting down?
indicates that then hard drive is on the way out
first step is to save everything onto an external hard drive
then take it to a computer repair shop for an inspection
check how much space is on the hard drive because if you have a lot of junk on it , that slows down the start up and shut down p[rocesses
you can go to device manager and do a defrag of the hard drive to free up space
Aug 09, 2017 | Time Computers & Internet
How to restore system
im assuming you have the recovery disk
Restart the computer and press the pause/break key on the keyboard.
This key will slow down the boot process and allow you to see the motherboard BIOS access key that you'll need to press in order to access the motherboard BIOS.
Press the respective motherboard access key and check the motherboard BIOS for a boot sequence.
Change the settings in the boot sequence so the primary boot device or the first boot drive is the CD-ROM or DVD-ROM drive.
Insert the system recovery disc into the disc drive.
Restart the computer and allow it to boot up before doing anything.
A black screen should show up with the words Press any key to boot from disc CD/DVD.
Press a key to have the system boot from the recovery disc.
Allow the system to load.
Follow the on-screen instructions on how to install the rest of the operating system.
There are many different settings for you to choose.
If the operating system is just a little out of whack, you can choose to repair it.
The system recovery disc will contain important drivers and software for all the components connected to the computer system.
If you do not have a system restore disc you can search the Internet for drivers and software that are packaged for your specific eMachines model.
Restore the BIOS to their default settings so the hard drive is primary boot sequence.
This is an optional step.
You can leave the CD-ROM drive as the primary boot drive, but it will slow down the startup process by a few seconds.
hope this helps
Sep 30, 2012 | E-Machines W3503 PC Desktop
Describe your Satellite L505DGS6000 Laptop AMD Turion II dualcore M500 160" HD LCD 4GB DDR2 320 (PSLV6U01F009) PC Notebook Problem . Computer would not boot up windows. Found that HD had failed....
if boot up but slow, you have tot test memory amount and speed and temperature of cpu cooler. if your hard drive is not have 100% smart feature test result, may be slow down. it is rarely with power problem. but you can test with another AC Adapter.
Oct 04, 2017 | Toshiba Satellite L505DGS6000 Notebook
Beep sound occurs at the time of booting in my HP G360 laptop & my system is very slow. Please guide me for recovering my problems-Thanks. I expect the reply as early as possible in this regard &...
system slow down is caused for different reason. Your registry may have many broken links in it. You may need to de-frag your hard drive. It may be time to purchase a new computer. The software companies keep applying fixes to the operating system which causes all machine to slow down after a while. good luck.
Feb 16, 2011 | Computers & Internet
Gateway gm5442 very slow to boot, 20 to 30 minutes.
You said you tried different CPU, but it was the same motherboard, right? Maybe the motherboard speed (data bus, etc.) is just slow. Otherwise, there's not much left to try if the hard drive works OK in another computer and you've tried upgrading the memory, CPU, and power supply.
May 29, 2010 | Gateway GM5442 Refurbished Intel Desktop...
My dell 610 laptop has started running slow
if you are experiencing these and unsure on what to do, better take your laptop a laptop tech, if you feel that you needed a hard drive change, then take it to a tech, have them replace your old hard drive
Nov 26, 2009 | Dell Latitude D600 Notebook
Vista desktop very slow to load
if you have any external drives eh flash , floppy, hard drive, sd card just try disconnecting them before you boot.
Also if you have installed any toolbars recently these can slow computers down quite a bit on occasion
Aug 26, 2009 | HP Computers & Internet
Computer crashed. Computer specialist restored drive. now cannot boot windows. Used restore disk. Did not work. computer boots dos screen then shuts down. boots again then shuts down.
Sounds like a Windows issue. Depending on how valuable it is to you to get your data off the drive, I would suggest buying a new hard drive (they are fairly cheap these days), installing Windows on that. Word of advice: Remove your old drive when doing the Windows install, so as not to accidentally select the hard drive your data is on. Once you have Windows installed, shut down your computer, remove the power cord, and install your old drive on a separate IDE channel or SATA connection. If your PC still tries to boot to the old drive, change the boot order in your PC's BIOS.
Aug 10, 2009 | E-Machines eMachines Desktop PC
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
Still... Slow in Booting and reading startup programs
Have you tried defragging you hard drive lately. Go into my computer, Move the mouse to your hard drive. Select properties. Select tools. Select defragmentation. Follow the instructions on the screen.
Aug 05, 2008 | Microsoft Windows XP Professional With...
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
24 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
