Question about Technics RS-TR373 Single Cassette Deck
Technics RS-TR373 is chewing tapes
Hi, My Technics RS-TR373 has decided to chew tapes when playing forwards on deck b. I have cleaned the capstans and its still no better as i first thought the dust on them was causing an imbalance and the tape to crinkle. not so. when playing side b the head spins 180 degrees and plays ok, when it soins back to play side a the problem starts leading me to think the head is not aligned.
am i right in thinking this and can the head be aligned easily?
  • whit_dan Jan 22, 2009
    cheers, i cleaned up the capstans and the rollers but its still no better.
  • Technics Master
  • 5,449 Answers
A lot of tape chewing problems are caused by the capstan roller being worn. Check for wear or oxide on that first.
Posted on Jan 21, 2009
Technics tape deck-rs-tr515 tape starts then stops-does it need a good cleanig
Hi there! A good cleaning will help with the fidelity of the machine but if I understand your problem then it can only be that the machine needs a good service like lubrication and new rubber belts capstan roller and so on.Try your tapes on another machine and check how the behave.as sticky cassettes I have seen ruined very expensive decks.
Oct 03, 2014 | Technics Audio Players & Recorders
Technics tape deck rs-eh600 wont play it just clicks
Another dual deck it seems- the unit will need service by a Technician, there is no magic that will make it work. It may be as little as a large belt. I would have to see the unit to tell you the exact cause.
Aug 13, 2012 | Technics Audio Players & Recorders
I have a Technics RS-TR373. Yesterday, during tape playing back, he sound suddenly stopped. The db level meter shows no sound being pickup. I switch to tape 2, it was the same. Tape was played (I can...
hi rich,
i had this problem it was touching the buttons that lost the sound to the speakers, do you have a re-set button if so press it if not press A or B to get your sound back if thats does nothing then try head cleaning tape as you might have some static thats transfered from your tape to your heads an anti- static head cleaning tape will do the job, you should use these cleaning tapes every week as the heads pick up a lot of dust particles and static that cause very poor reproduction and qulity such as crackling and muffled repro,
hope this helps
Jan 22, 2011 | Technics RS-TR373 Single Cassette Deck
Where can I find a power cord for my technics stereo cassette deck RS-B282?
Not sure what is odd about it-is it a regular IEC 3-prong? Mouser may have a cable if it's something else.
Dec 20, 2010 | Technics RS-TR373 Single Cassette Deck
Tape deck not working on a technics rs-eh600. Small belt has slipped off, need advice in putting back on.
My tape deck is not working. When starting play it goes forward and then reverse. What can I do?
Apr 02, 2010 | Technics Audio Players & Recorders
No sound from double deck
Look around for micro switches. They might have broke or jammed or something.
Dec 17, 2008 | Technics RS-TR373 Single Cassette Deck
I did not use deck for 2 years and no sound now
the answer is in your question lack of use power supply capacitors and transistors if you have left in loft cold low temps ruin hi fi
Technics 373 Dual Cassette - Playback Stops
Suggest having a good clean and replace belts. If it stops around halfway on a C90 or near the end then there's a load problem on the take up reel, before halfway the supply reel.
Dec 13, 2008 | Technics RS-TR373 Single Cassette Deck
RS-dc10 DCC replacement head
You should contact Panasonic, or Matsuchita. They can most likely give you their authorised parts dealer. You may find the head to be a little expensive.
You will have to have an experienced tech install the head for you. He will have to do a tape path alignment with the frequency response calibration.
Jerry G.
Oct 02, 2008 | Technics RS-TR373 Single Cassette Deck
Technics RS-TR373 Single Cassette Deck Logo
731 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
