Sharp ar5127 error F5-02 - Office Equipment & Supplies
3 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: my copier is: sharp AR5127
H means HEAT. You have a bad fuser.
Posted on Mar 31, 2010
copyTEQ
  • 5 Answers
SOURCE: Error L6-10 sharp AR5127 Problim i dont know I
you may need to replace the polygon motor from the LSU tosolve this problem...
Posted on Aug 22, 2011
What could be the cause of f2-02 in sharp copier ar5127
You need to first check the toner cartridge to make sure its ok (May be bad). The other problem can be the developer being depleted causing the sensor not to detect the proper density whcih is one cause of the errur code.
Printer Repair Service in Miami and Fort Lauderdale FL
May 20, 2016 | Sharp Office Equipment & Supplies
How to remove code f2 from a Sharp AR-5316
What is the next after f2- or if f2-64 check development un or connect the connector chip.Replace development unit.
Jun 10, 2014 | Sharp AR-5316 Advanced Digital Imager...
You forget to connect the laser cable to main-board.
Jan 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
Toner leaking model AR5127 how to fix it
Hello sir; It seem like the toner recover blade need to replace it located at drum cartridge.
Jan 18, 2010 | Sharp AR-5320 Black and White Copier
As the bag of a sharp 2114 error h3
SHARP - 2114 - L8-1 - zero cross signal error
SHARP - 2114 - L8-3 - auto-exposure sensor malfunction
SHARP - 2114 - H2-0 - Fusing unit temperature error
SHARP - 2114 - H3-0 - Overheated fusing unit
SHARP - 2114 - H4-0 - The fusing unit doesn't heat up
SHARP - 2114 - U2-1 - EPROM error
May 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
H4-00
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and rarely the temp sensor.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Feb 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar5127 copia eror slution
Check the scanner lock located under the scanner section on the left side. Change the position of it.
If it sitll locks the scanner could be jammed up by the cable. The scanner glass has to be removed to fix that.
Jun 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
jasbo
jasbo
