Question about Sharp 27SC260 27" TV
"Fisheye" effect I have a Sharp TV, model 27sc360, and the image is distorted in what can best be described as a "fisheye" effect. The top and bottom few lines are cut off in the center, and the image is squished both horizontally and vertically at the sides. The effect is not huge, but it's annoying. Is this something that can be fixed by getting into the service menu? If so, does anyone know how to get into it and what parameters to change?
SOURCE: Accessing Menu Sharp TV
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
Posted on Aug 25, 2007
  • 1074 Answers
SOURCE: tv will not cut on
there is no recall on sharp tv that i know about if your tv is still on warranty take it back to the supplier.if the warranty is finish call a tech the tv has a problem in the power supply and related circuit.good luck.
Posted on Apr 14, 2007
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
SOURCE: Sharp Tv 25E-M50
Posted on May 22, 2008
  • 346 Answers
SOURCE: Blue horizontal and vertical lines
poor convergence
Posted on Nov 12, 2008
I have a Nikon D-40 I'm currently using a 55-200
Fisheye is the extreme of a wide angle lens. I think you are not using a fish eye lens, but a fish eye adopter. That is a lens that will "shorten" the focal length of a lens most of the time with 30 % sometimes with 50% when you put it in front of your lens. So you could make a 24 mm lens look or act like a 12 mm.
On your tele lens this only will slightly shorten the 55 mm, but even 50 % of 55 is 27 mm and can't be seen as a fish eye.
I think when you put this on a short lens, the picture you get will be round, like you were using a real fish eye.
Feb 28, 2012 | Nikon Cameras
I ordered a digital concept wide macro fisheye lens at ebay . do you have sample vids and pics with this lens? thanks!! my order is yet to arrive,,,
I have a few shots from a similar model:
Aug 15, 2011 | Cameras
I left my 60 inch rear projection mitsubishi HD 1080 on overnight as I fell asleep in front of it for about 5 hours (11pm - 4am). This morning when I turned it on the picture is doing a fisheye effect on...
It sounds your Mitsubishi rear projection tv got problem with convergence output chips failure, I'm not aware about model number of this tv so unable to provide you specific info however, it is hardware failure and few parts need to be replaced by tv repairman.
Convergence output chips make align picture on front screen and if they stop working, you will see 3D look or bowed picture with different colors.
Contact local tv repair shop to fix this issue in tv.
Nov 17, 2010 | Televison & Video
How do I get my lomography fisheye to advance?
Turn the thumb wheel located behind the shutter release button until it stops at the next frame.
Note that on your model the MX button (Multiple eXposure) to the left of the thumb wheel often gets stuck and prevents the film from advancing. The button should be firmly to the right when not in use. If the MX system is broken there's nothing you can do as the parts cannot be repaired or replaced. All LOMO and Holga models are extremely cheaply made plastic "toy"cameras and are not designed to last. Most have a maximum design lifespan of ten to twelve rolls of film, the FishEye model is designed to last just half that. It's only in Western countries that these models sell for ridiculously high prices, as an example my Lomo FishEye cost me 48 Hong Kong Dollars (that's just under GBP£4 or just over US$6). Back home in the UK they sell for ten times more.
The above explanation is not meant to be disparaging about your camera, but is just to illustrate that these cameras are really built from the start as disposable cameras which have the added bonus of being reusable a few times so cannot usually be repaired when broken.
Oct 09, 2010 | Lomo Fisheye 35mm Film Camera
When I get my prints developed from my Fisheye 2 camera, all the images are to one side. The fisheye image has a chunk missing from it and appears like a 3/4 circle, with about 1/4 of the print just...
Check the negatives: you should clearly see that the images are complete, although where they've been cut into strips it's possible that the cut may have gone through an image. If there are very few complete circular images, then you have a camera problem and problems are not at all rare on Lomo cameras which are in general of absolutely dreadful quality.
if you can eliminate the camera as the cause, then the fault is with the photographic processing service. The process is mostly automated, and the machine which makes the prints from the negatives expects to find nice regular rectangular images with neat straight unexposed lines between them. Your FishEye 2 produces circular images instead with wide hourglass-shaped unexposed partitions and so it's confused the machine.
If you've used an ultra-budget postal processing service then they might agree to reprint for you but will usually (and entirely fairly) point to a clause along the lines of "at these prices, this service is for regular 35mm prints only". In future always use local processing shops and tell them clearly what to expect as they can manually intervene and ensure that the prints come out correctly.
This should solve your problem, if so please rate my answer.
Feb 23, 2010 | Lomo Fisheye 35mm Film Camera
I just purchased the Zeikos fisheye lense for my 50mm Nikkor lens and when I attach it, it doesn' take fisheye photos - just regular with some distortion around the edges... am I using this incorrectly?...
The 50 mm lens is a full frame lens, and the D80 is a DX camera. This means that the 50mm lens puts an image out that is bigger than what the D80 can "see". The good part of this is that the D80 (and most of the other Nikon DSLR's) use only the image from the center part of an older lens. The bad part is that if you put the fisheye filter on it, the fisheye effect that is mostly seen at the edges of the lens doesn't show up on the D80 sensor. If you could put the fisheye filter on a DX lens, it would give you the full effect.
Sep 24, 2009 | Nikon D80 Digital Camera with 18-135mm...
Like to fit my bronica fisheye p e into nikon f 5 camera
The lens you're refering to is the Fisheye-Zenzanon-PE 30mm, yes? As far as I'm aware no Bronica ETR > Nikon F adaptor has ever been made, and if one was to be it would be rather cumbersome.
You're probably better off selling it and using a Nikon Fisheye-Nikkor 16mm 1:2.8 in its place.
Oct 25, 2008 | Bronica PS Zenzanon (1.4x) (bq1275) Lens...
Mitsubishi Diamond Series CS-27609 problem...image looks "fisheye"
2 years later and I may have a solution for you
I has a similar problem and I didn't quite fix it but made it less noticeable.
Press menu and then the code 2-3-5-7, this enters a service menu. Press Audio/Video to go between the options to get to options 40-50 to adjust geometry. Be sure to write what setting there on before you change it (even if they're wrong) just in case.
Its just trial and error from there, and hope I can still help.
Oct 27, 2007 | Mitsubishi CS-27609 27" TV
Sharp 27SC260 27" TV Logo
104 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
