Question about HP w1907 LCD Monitor
Screensaver will not turn on after inactivity
Set to turn on after 5 minutes of inactivity. Worked fine but all of a sudden it quit working
  • HP Master
  • 3,904 Answers
This is an adjustment made in the control panel under I believe Display. From there you will have an option for Screen Saver. It should all be in there.
Posted on Jan 21, 2013
Model 665.72002. Why aren't start, hour, and minute selectors working?
It's a crapshot. U can try cleaning the contacts on the touch pad but to have three contacts go bad at the same time is supicious. I would say that it is the control board that is the culprit.
Mar 10, 2016 | Kenmore Kitchen Ranges
I connected my Toshiba L305 laptop via a VGA cable to my hdtv and it worked beautifully for a while. Suddenly, the TV indicated that there is no signal. I
If you were using the computer at the time, it may be a cable/plug/socket failure. Try a different cable.
If you were watching a movie, you may want to check your screen saver settings. Try doing what you were doing and see if it disconnects after a specific time (so if your screensaver is set to 10 minutes, does your TV lose signal after 10 minutes?).
Apr 30, 2012 | Toshiba Satellite L305-S5911 Notebook PC
My base unit keeps shutting off after about 8 minutes. Sometimes it comes on in a minutes and other times it must be reboot (unplugged.) Is it defective?
I just had the same issue - i've had them for about 18 months and they were working fine with my regular tv set - connected the red/white analog plugs to the back of the tv and then other 3.5mm end to back of base... but now, i just bought an LG hdtv and had to reverse that connection... 3.5mm to the tv and the analogs back to the base... worked ok for about 10 mins then the base shut off... seems that the volume setting on the hdtv wasnt up high enough to "register" with the base - base thought nothing was happening so it automatically shut off for "inactivity" - so, when plugged into tv, I turned the tv volume way up to 100.... seems to have worked - just need to be sure to turn the volume on the tv back down before removing the headphone jack!
May 11, 2010 | Sony MDR-RF970RK Headphones
Blue screen after less than 5 minutes after boot-up. IALMRNT5 error.
Try booting in safe mode and try system restore, by clicking on start>All prog>accessiories>system tools>system restore. and restore the system to an earlier time when it was working fine.
May 19, 2009 | Computers & Internet
Come on, boots up, then shuts down 5 - 10 minutes later.
check your power options make sure you don't have hibernation enabled, its in the system control panel. try booting from a linux live cd like Ubuntu which you can download for free. If it runs fine under linux, its a windows problem, if it keeps shutting down its a hardware problem. Could be bad ram, or CPU overheating.
May 09, 2009 | Computers & Internet
Camera will pan to an area but will not stay there.
Most PTZ cameras have an "inactivity" setting. If no command inputs are entered into the keypad for a programmed amount of time, typically between 30 seconds - 5 minutes, the camera will return to it's pre-set position. You should be able to turn this off in the camera programming. A good way to test to see if this is the problem would be to point the camera to an area, then make very tiny adjustments to the direction every 2-3 seconds. If the camera does not go to the pre-set, then inactivity is turned on. Also, point the camera to an area and time how long before it returns to pre-set. If it is the same amount of time on every occasion, this would also indicate that inactivity is turned on.
Let me know if this does not work, or if you don't know how to access the programming menu - steven.burman@commandtechnologyassociates.com
Nov 18, 2008 | Pelco ES3012 5MLZ30PW Esprit High Res...
Screen saver no longer works
Well, you have two options to look at:
1st one:
Since your laptop is Dell, I presume that you use Dell Media Software.
Other people had the same problem too. Try disabling this program to check if your screensaver is working.
Other programs that might conflict with the screensaver might be:
1. Ehtray.exe.
2. DVDLauncher.exe
3. Power DVD
4. PCM service.
Otherwise there is a known bug:
Try updating (flashing) the BIOS with an updated version. This seems to be a problem Dell was aware of an made available a "fix."
How To:
http://support.dell.com/support/edocs/sy...
Download Location:
http://support.dell.com/support/download...
Hope that helps,
TrustMe
Apr 15, 2008 | Dell InspironTM 1501 Notebook
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
POWER WON'T COME ON
try unpluging and plugging back in
Jan 15, 2008 | Memorex MVD2042 DVD Player
HP w1907 LCD Monitor Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
