Question about Cameras
Mode dial not in proper position Nikon S9200
SOURCE: MODE DIAL IS NOT IN PROPER POSITION
Try turning the mode dial again. It may not have been turned properly.
Posted on Jul 18, 2008
SOURCE: Mode dial is not in the proper position
how to take good pic beside use the iso mode
Posted on Nov 13, 2008
dlundmark
  • 797 Answers
SOURCE: When you turn it on the screen displays
Something seems to be broken or off between the mode dial and the switch. It also may have broken internal parts.
I have had a camera with a similar problem. It was that the small switch inside was broken, and could not be repaired.
These mode switches can be changed, but will require a digital camera repairman to do such a job. It also could be sold for parts/repair on a site such as Ebay.
Posted on Aug 31, 2009
SOURCE: Mode Dial and Lens Problems! Nikon Coolpix 4600
i had the same problem try this: tap the outside of the dial lightly while turning the camera on it should basically "pop" right out!!!!!!!!;)
Posted on Dec 08, 2009
dj_relly999
  • 4070 Answers
SOURCE: lumix camera says mode dial is not in proper
Hi and welcome to FixYa!
Please try to remove the battery and let it sit for atleast 5mins. then reconnect it again. This should reset the system and can resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Dec 21, 2010
How do I fix or resolve my Nikon coolpix p7000 camera, mode dial is not in proper position?
Take the camera to a camera shop. They can gently pry off the knob and re-attach it in the proper position. It should be just a splined press fit and therefore not an expensive fix.
Oct 10, 2016 | Nikon Cameras
Nikon Coolpix S8100 and when I turn it on it says Mode Dial is not in proper position
Return the camera right away, it is clear this is a manufacture defect, nothing more can be done.
Mar 22, 2012 | Nikon S8100 Digital Camera
My camera when it turns on says ' Mode Dial Is not in the proper posistion ' I haven't dropped or anything! Will my warrinty cover it!?
Hi jayderehbein,
Make sure that the dial for selecting either video capture or image capture is not stuck somewhere in the middle , therefore a good idea would be try moving it to different positions and then back to the usual image mode and this message would go away ...
Hope this helps ..:) Your feed back would be appreciated.
Jun 19, 2011 | Nikon S8100 Digital Camera
I have a Nikon D3100 and surprisingly the dial mode does not work properly. I mean when I turn it, at some modes, it shows the selected mode correctly on the display, but not for all
Hello mehran_vafae, is supposed to have put a DX lens.
The mode dial, select in what way is going to take a picture.
You can make combinations according to the mode set in the mode dial, with the Fn key / command dial, command dial / aperture A mode, command dial / shutter speed S mode, Full Auto / + / - compensation sw, etc. ..
Please carefully read the user manual supplied with your camera and if it fails take them to Nikon service.
Regards
Mar 21, 2011 | Nikon Cameras
Nikon D3100 - how to set quick response mode or delayed release so I can use remote control. Thanks
For Quick Response Mode and other Release Modes, please see "image1":
For remote control shooting or Bulb mode, see "image2":
image 2
Nov 24, 2010 | Nikon Cameras
Nikon camera D300 mirror up/down shutter permanently up
Please check whether the mode dial is on 'Mup' or 'Lv'. If it is, then the camera is on mirror lock-up position (Mup) or LiveView mode (Lv). Mup is mirror lock-up and Lv is LiveView. It could be in Lv mode if you can see the image on the LCD, but not through the viewfinder. If it is on Mup mode, both the viewfinder and the LCD will be blank. If any of these is selected, pressing down the mode dial lock, rotate the dial to 'S' mode.
Jul 29, 2010 | Nikon D300 Body Only Digital Camera
Nikon D300 mirror sticks
Please check whether the mode dial is on 'Mup' or 'Lv'. If it is, then the camera is on mirror lock-up position (Mup) or LiveView mode (Lv). If any of these is selected, press the mode dial lock and rotate the dial to 'S' mode.
May 19, 2010 | Nikon D300 Body Only Digital Camera
Warnin! Mode dial is not in the proper position
I used to have the same problem. Make sure the picture of the setting you are using on the turn dial is lined up with the beige pointer on the top of the camera. When you turn the dial, you can feel it lock into position. It could be that the dial hasn't quite clicked into the right position and just needs adjusting.
Aug 08, 2008 | Nikon Coolpix 2100 Digital Camera
May 04, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Cameras Logo
97 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
