Question about Hotpoint RLA30 Compact Refrigerator
Remove drip tray on hotpoint future rla30 re smell
Internally clean/drain hole clear....smell rises from top of rear vent
4 Suggested Answers
jtbjtb
  • 135 Answers
SOURCE: Smell
Your whole freezer bottom is probably removeable. you mat have to remove the doors and the separator bar in front to get this out. Then you will be able to access the spill.
Posted on Dec 31, 2008
Sea Breeze
  • 4654 Answers
SOURCE: I have a hotpoint refrigerator model CSX24XJ that
There is a leak somewhere in your defrost drain. Most times this is caused by a blockage near the area of the leakage. Below is a link to a very informative way to help you resolve the problem. Thanks.
http://appliancejunk.com/forums/index.php?topic=22.0
Yes your model has 2 drip trays. 1 is below the evaporator inside the freezer and behind the back wall covering the evaporator. The other is below the refrigerator next to the compressor where the condenser fan heats the water and returns it back to the air inside your home. Thanks, Sea Breeze
Posted on Jun 28, 2009
  • 4793 Answers
SOURCE: Swap door sides on hotpoint future RLA30 fridge?
tip unit over on side,placing an old blanket or similar on floor under unit.there are 3 little bolt/screws holding each bracket to the underside of unit,unscrew these/lay brackets on floor, slide door down off pin on underside of top.and unscrew this pin.change over from right to left replace door onto pin replace bottom hingepin,adjust door for" squareness " and tighten all screws lift back upright and switch on...will take a little time to settle down temp wise.... make sure seal sits tight all round good luck ..geoff
Posted on Feb 19, 2010
WATER COMING FROM UNDERNEATH SALAD DRAWER
My guess is that the drain tube is still clogged.
Sep 18, 2014 | Hotpoint FFS70 Bottom Freezer Refrigerator
I have an SA12059 Windchaser portable a/c. After using it and rolling it around, the top condensate tank drips lots of water. I tried to drain the bottom tank via the hose, but the top tank doesn't seem...
There is not actually a top tank, just a drip tray with little drain holes that become easily clogged. After removing the rear cover of the unit and cleaning thoroughly, you can use a can of air (like the ones to dust pc's) wth the little straw attachment to try to clear te clogged drain holes in the tray below the evaporator. If your unit froze up condensate may have overflowed into the fan area. Let the unit defrost, and run it in fan mode for awhile to dry this moisture out.
Sep 01, 2013 | Windchaser PAC9 Air Conditioner
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Feb 19, 2010 | Hotpoint RLA30 Compact Refrigerator
Water draining into frig
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jul 06, 2009 | GE GTS22KBP Top Freezer Refrigerator
Freezer ice
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 08, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Smell
Dec 31, 2008 | Hotpoint HTH16BBSR Top Freezer...
How to empty drip pan
At the back of the food compartment where the water collects ,there is a drainage hole, this is blocked up,poke a long thin piece of wire or similar and poke it down the hole, this should clear the blockage,
If the water does not drain away then you need to go the rear of the frig and clear the rubber or plastic hose that you will see on the top of the motor compressor. this should solve the problem.
Plz rate this solution.
Thanks. and merry xmas.
Nov 06, 2008 | Hotpoint RLA30 Compact Refrigerator
Hotpoint RLA30 Compact Refrigerator Logo
52 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
