Question about KitchenAid KV25G0X Stand Mixer
Mixer doesn't move
    New Friend:
  • 21 Answers
The engine runs?Swept gear; need to disasemble and inspect.
Posted on Jan 01, 2013
250 watts k45ss classic stand mixer doesn't run
My first guess would be the speed control plate. It has three screws in an upside down triangular shape. The two screws on top control and adjust speeds 1 thru 6, and often times just one screw being out a 16th of a turn will shut the mixer off completely. I would venture that when you were removing the two stud bolts you moved the adjustment screws on the speed control plate. Remember that even a slight movement can shut down your mixer, take a phillips screwdriver and turn the top left screw one quarter turn while the machine is on, it can start on you so don't be shocked and jump with a loaded screwdriver in your hand at the back of an electrical device, stay calm, if no start then try the left screw a quarter turn, if it does not start go to a half turn on each screw, if still no start turn thr screws back to the start place and try the bottom screw a quarter turn left and right, if you do not start by now, then something is wrong in another place, go back to the brushes and take them out and check how you put them in, these are the two most common problems with a no start mixer. If this does not fix your problem or get the mixer to start please come back here with more info. If you motor raced in the first place then I would suspect the phase control board, but when it came back to normal speed it leades me away from the phase board. When the phse control board goes out the mixer only works at high speed. So please let us know so that we can help further.
Mar 28, 2013 | KitchenAid K45SS Classic Stand Mixer
The mixer runs but the beater doesn't turn. Drive shaft?
a gear or gears. their usually plastic and will damage before the drive shaft
Feb 07, 2013 | KitchenAid K45SS Classic Stand Mixer
Hi, I recently bought an old AE200 Hobart mixer from a catering auction...plugged it in & guess what?? does't work. I can hear the motor running, but when I put it in any of the three gears..it...
You will probably want to remove the two silver looking inspection caps. Just carefully pry them up and remove. Then you will be able to get a finger hold on the transmission cover. It has one or two locating or dowel pins that keep it in place. What I normally do is take a soft mallet and tap on the cover while gently lifting one end, then do the same to the other side until you have it loose enough to lift off. I know this because I just spent the last 4 months working on my A200 mixer. I'm not sure exactly what the model AE 200 is, though. I hope this was helpful.
Nov 07, 2011 | Hobart A200 Stand Mixer
Head won't lift without force. The head lock is in the Unlock position but it doesn't lift up easily. I have to stand behind the unit and use a lot of force to pull it up. It was fine one minute...
Presuming all looks OK near pivot & lock mechinism? can you see the locking hook in rear of mixer head at the hinge area directly behind lock lever, and is it nested in the slot on the base, or is it jamming up outside the stand and scratching it up?
There is a flat-head height adjust screw to control clearance between spatula and bottom of bowl visible from head-back position- leave it alone. There is a headless set screw visible when mixer is upside down to hold the pivot pin secure. This must be loostened with long-shaft flat screwdriver to remove the pivot pin for head removal if necessary ---avoid removing the pin if possible.
Is the hinge stuck with film of sticky sugar, milk-glue residue, ot the like? That is most common cause, distant second is the lock mechinism alignment (very rare)
Its important to keep head from wobbling side-to-side in use, so dont file or sand anything
Can telephone 609 213 2222 if necessary no charge for my talk.
Oct 16, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Our switch doesn't stay in off position
you probabley bent the switch lever so the little indent on the lever won't stay positioned in the off detent. probabley need new switch lever. part doesn't cost much .not hard to put in if your mechanicly inclined , if not a repair center can do it for you.
Sep 12, 2011 | KitchenAid 32685 Mixer
The mixer simply doesn't turn on. Worked fine yesterday. Today it seems like it's just dead
HI.Let me jusk ask if yiou also tried to connet to another socket.Let me just clarify that the motor itself did not work /rotate as well.Prior to that situation,have you tried to mix more than what is the capacity of your mixer.If possible motor was overworked/that's why its coil was burnt.There. are possibilities then. First might be that the mixers terminals inside will no longer engaged properly that's why it opens the circuit.Second the motor isn't working because the rotor and armatures coil was burnt because it runs beyond its maximum wattage capacity that's why it draws much current beyond the rotors coil capacity.Did you mixed something heavy.the motor works heavier the last time you used the unit?
Jul 23, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I have a Kitchen Aid k45ss that was dropped a few years ago. I works fine but the speed switch doesn't want to stay in the off position so we have to unplug it. I opened the unit and the switch...
When you said "the speed switch doesn't want to stay in the off position", you meant to
say "the speed switch in the OFF position does not turn OFF the mixer", or "the speed
switch physically cannot be moved to the OFF position"?
In any case, try to adjust the mixer speeds.
Obtain a copy of the K45SS Repair Part List from Kitchenaid.com.
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 21, 2011 | KitchenAid Food Mixers
Moving our mixer
Offer a free pizza night to your biggest & strongest friends and as they walk in the door tell them they can eat all they want but, they have to move your mixer in return. Most of your larger, well known rental places should have what we call in the business as roller skates or appliance moving casters. They are a tripod type heavy duty caster that is placed under each corner of the mixer and can either be strapped or bolted down. You could also call a local commercial kitchen equip service & install company like Ecolab GCS, they move & install equipment. 800-822-2303
May 15, 2009 | Hobart H600 Stand Mixer
KitchenAid KV25G0X Stand Mixer Logo
63 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
