Question about Rhinotek Digital Imaging Suppl HP Color Laserjet CP4025, CP4520, CP4525 Series Printers
HP Color Laserjet CP4525 Unlock Menus
I can not access the configure device menus because the menu is locked out. Anyone know how to reset the lock option?
How do I reset hp laserjet p3015 to factory settings
  1. Press the Menu button .
  2. Open each of the following menus. Press the down arrow to highlight it and then press the OK button to select it. CONFIGURE DEVICE. RESETS. RESTORE FACTORY SETTINGS.
Dec 04, 2016 | HP P3015 Laser Printer
Cm6040 unlock menu
Navigate the Administration menu
From the Home screen, touch Administration to open the menu structure. You might need to scroll to
the bottom of the Home screen to see this feature.
The Administration menu has several sub-menus, which are listed on the left side of the screen. Touch
the name of a menu to expand the structure. A plus sign (+) next to a menu name means that it contains
sub-menus. Continue opening the structure until you reach the option that you want to configure. To
return to the previous level, touch Back.
To exit the Administration menu, touch the Home button in the upper-left corner of the screen.
The device has built-in Help that explains each of the features that are available through the menus.
Help is available for many menus on the right-hand side of the touchscreen. Or, to open the global Help
system, touch the Help button in the upper-right corner of the screen.
The tables in the sections that follow indicate the overall structure of each menu under the Administration
menu
Aug 13, 2014 | HP Color LaserJet CM6040f MFP Q3939A...
How i replace ETB for hp cp4025
Replacing the Transfer Belt (ITB, Transfer Kit) HP Color LaserJet CP4525 CM4530
1. Open the printer's right side door.
2. Use the blue lever (see callout 1 in picture below) to lower the secondary transfer assembly.
3. Grasp the small handles on the transfer belt assembly (circled in blue in picture below), and begin gently pulling the assembly out towards you, until a set of 2 larger handles pop free on the sides of the transfer belt assembly.
4. Now grasp the larger handles on the transfer belt assembly, and continue pulling the transfer belt straight out of the printer until it is completely removed.
5. Avoid touching the surface of the new transfer belt. Install in reverse order, sliding it securely into the machine.
6. After replacing the Transfer Belt, it's a good idea to perform a Full Calibration (or even several Full Calibrations in a row, if you are having print quality issues). Full Calibrations help with print quality by aligning the color tones, the drums, and the color plane. Each Full Calibration takes about 4 minutes. To perform a Full Calibration: Press MENU to enter the menus. Press Down Arrow to highlight CONFIGURE DEVICE. Press Checkmark to select CONFIGURE DEVICE. Press Down Arrow to highlight PRINT QUALITY. Press Checkmark to select PRINT QUALITY. Press Down Arrow to highlight FULL CALIBRATE NOW. Press Checkmark to select FULL CALIBRATE NOW. Wait for the printer to calibrate (usually takes 4 minutes or so), and then print a test page. If print quality still needs improvement, repeat the Calibration. If multiple Calibrations don't help, some of the toner cartridges may need replacement.
5e5fcf65-5757-40c3-a110-1a2864982d2e.jpg 554a3a0e-c038-46ec-983d-7467c3deeccf.jpg 7883eb6b-6a29-43fd-b69a-0ff825f60373.jpg bb2de9b0-8f0f-4f6a-a69f-ed1001f8bd09.jpg
Jul 15, 2014 | HP Laserjet Cp2025n Printer
How do you reset an hp 3500 color laser jet printer?
follow the steps :
  1. Press MENU to enter the MENUS .
  2. Press c00047416.gif (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press c00047417.gif (Select) to select CONFIGURE DEVICE .
  4. Press c00047416.gif (Down arrow) to highlight RESETS .
  5. Press c00047417.gif (Select) to select RESETS .
  6. Press c00047416.gif (Down arrow) to highlight RESET SUPPLIES .
  7. Press c00047417.gif (Select) to select RESET SUPPLIES .
  8. Press c00047416.gif (Down arrow) to highlight NEW TRANSFER KIT .
  9. Press c00047417.gif (Select) to select NEW TRANSFER KIT .
  10. Press c00047416.gif (Down arrow) to highlight YES .
  11. Press c00047417.gif (Select) to select YES . The transfer unit count is reset and the printer is ready to use.
Mohamed Hejazi
Afaqnama-LIbya
ipg@hplibya.com
Feb 27, 2013 | HP Color LaserJet 3500 Printer
Reset hp 1515n
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
settings (except language) via the control panel or software
NOTE: This service menu item does not reset factory-settable settings, including formatter
number, page counts, factory paper settings, language, and so on.
NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus.
2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
The product automatically restarts.
Jul 13, 2011 | HP LaserJet CP1515n Printer
Hi, I need to reset my Printer using cold reset option. please help.
? Cold Reset
CAUTION All HP Jetdirect settings are also reset. Be sure to print a configuration page
before performing a cold reset. Make a note of the IP address that is listed on the Jetdirect
page. You must restore the IP address after performing a cold reset.
Use this item to unlock menus that have been previously locked and to set all control panel menu
items (including EIO settings) back to the factory defaults. However, using this item does not clear
the values in the SERVICE menu (such as the serial number and page counts).
NOTE Before performing a cold reset, print a menu map and a configuration page.
Use the information on the configuration page to reset any customer-set device configuration values that the cold reset procedure changes.
Apr 14, 2011 | HP LaserJet M5035 MFP Printer
How do i perform a cold reset on a laserjet 2600n printer
Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
  1. Press (Down Arrow) to highlight Configure device menu .
  2. Press (Select) to select Configure device menu
  3. Press (down arrow) to System setup menu
  4. Press (select) System setup menu
  5. Press (select) Resets menu
  6. Select RESTORE FACTORY SETTINGS.
Dec 03, 2010 | HP LaserJet 4600dn Color Printer
Have a hp laserjet 3005n printer, that will not boot up. Is there a way to reset it?
Thank you for contacting FixYa with your printer inquiry.
Here is the info you requested on a reset. We may have other issues including the formatter.
HP LaserJet 3005 Cold Reset A cold reset unlocks menus that have been previously locked and sets all control panel menu items (including EIO settings) back to the factory defaults. However, it does not clear the values in the SERVICE menu (such as the serial number and page counts).
NOTE Before performing a cold reset: print a menu map and a configuration page. Use the information on the configuration page to reset any customer-set device configuration values that the cold reset procedure changes.
1. Turn the device off. 2. Turn the device on. When the memory count begins, press and hold the [SELECT] button. Continue holding down the [SELECT] button until all three device control-panel lights flash once and then remain on. This might take up to 10 seconds. 3. After the message SELECT LANGUAGE appears on the display, press the [UP] button or [DOWN] the button until COLD RESET is highlighted. 4. Press [SELECT] . The device performs a cold reset and then continues its power-on sequence. 5. Check all I/O settings and reset any customer-set device configuration values.
If that fails try this info: The formatter Part # is Q7848-61002
Formatter Questions and answers Forum: http://www.fixyourownprinter.com/forums/laser/54166
Hope this helps helps. Please keep us updated and remember to rate this answer.
Dec 08, 2009 | HP LaserJet P3005n Printer
I changed the trasfer kit on my HP Color LaserJet 3500 and now the print is very light. I used and OEM transfer kit and followed the instructions provided by HP. Help
Calibrating the printer
Calibration is a printer function that optimizes print quality. If you experience any print quality
problems, calibrate the printer.
1. Press MENU to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
Hope this works for you
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
HP Color Laserjet 3500 Problem
If you are sure the diagnostics show the colours correctly, one thing I would look at is to see if it had a colour profile set up for it.Don't know whether this printer normally has, if it has not I would suggest reinstalling the driver. To check - Start/Printers & Faxes/ Rt click on printer then properties, look under Colour management tab. Pete
May 25, 2006 | HP Color LaserJet 3500 Printer
Rhinotek Digital Imaging Suppl HP Color Laserjet CP4025, CP4520, CP4525 Series Printers Logo
246 people viewed this question
Top Rhinotek Digital Imaging Suppl Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Rhinotek Digital Imaging Suppl Office Equipment and Supply Expert? Answer questions, earn points and help others
