Question about Dremel Saws
I need parts for a Dremel 580-2 table saw............
I need parts for the 580-2. 990942 table cover 406068 wrench 990951 rubber mounts 990955 mounting screws 990938 screws (to mount blade guard) Vacuum attachment Contact: keimach@yahoo.com Thanks.................................
HOW DO I OIL THE DREMEL 1830 SCROLL SAW?
  • page 15 Squirt a generous amount of SAE 20 oil around the shaft end and bronze bearing
  • Dremel 1830 Manuals
Sep 16, 2014 | Dremel 1830 120V 18" Scroll Saw
The pot metal in front of thequick release tension lever has broken and fell out. can I still use the saw If not where do I go to get another one 1830 120v 18inch scroll saw dremel
I believe the part you are looking for is called a "locking rod" dremel part number 2610922661, this is the black painted pot metal that is about 3" long attached to the upper arm rocker with a parallel pin, and the flip clamp (blade tensioning assembly) or it could be the small piece attached to the tension assembly that the blade attaches to which is silver and called the "blade holder assembly-top" part number 2610922683. I would recommend ordering both directly from Dremel CS 1-800-437-3635. I broke the locking rod on mine. I emailed dremel, and they emailed me back the next morning with a schematic, and parts list. I bought 2 and paid $10.41 total.
Mar 08, 2011 | Dremel 1830 120V 18" Scroll Saw
I have a 1680 scrollsaw and no manual. Where is oiling required?
Lubrication
ARM BEARINGS
Lubricate the arm bearings with oil after 10 hours of use.
Re-oil after every 50 hours of use or whenever there is a
squeak coming from the bearings.
TO LUBRICATE
1. Turn saw on its side (Fig. 18).
2. Remove rubber plug to expose bronze bearing.
3. Squirt a generous amount of SAE 20 oil around the shaft
end and bronze bearing.
4. Let the oil soak in overnight in this condition.
5. Next day repeat the above procedure for the opposite
side of the saw.
You can get the manual on the link below. scrool down to product details to get it.
http://www.amazon.com/Dremel-1680-6-Horsepower-Benchtop-Variable/dp/B0000302YQ
Good Luck
Dec 04, 2010 | Dremel Owner Operator Manuals Moto Shop...
Have a 4"blade dremel small
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or Dremmel.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 11, 2010 | Dremel Garden
I have broken the switch assembly on a Dremel 1830 scroll saw.I need the cowling. Hit by a board
I would go to Dremel.com and type in your model number, they also have a toll free number so you can talk with one of their techs to get the correct part.
Oct 08, 2009 | Dremel 1830 120V 18" Scroll Saw
Need a rocker switch for a Powermatic 63 A Artisan table saw part number 6285322
If you want to buy a new one, the Grizzly G1022 Table saw is an exact replica of the PM#63. A owners manual and parts list is available at their website. Grizzly.com
Jan 03, 2009 | Powermatic 1791227K Model 64 10" Artisan...
Saws Logo
125 people viewed this question
Top Dremel Saws Experts
JonSnell Electronic
JonSnell Electronic
Terry
Terry
Are you a Dremel Saw Expert? Answer questions, earn points and help others
