Shredder pc line sm10 making grinding noise and stopped working
Started making grinding noise now not shredding at all
SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
Posted on May 21, 2007
SOURCE: My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Posted on Sep 08, 2007
SOURCE: Loud grinding noise when the shredder is on.
Your gears may be stripped - mine were. Time to get a new shredder
Posted on Sep 02, 2008
  • 35 Answers
SOURCE: The shredder jammed (too much paper) then stopped
Chances are, the overfeed caused the teeth of the gear that operates off of the motor to break.
This is very common in less expensive machines. I don't know if OM will let you return it because I don't know there policy. Most of the time retailers will attribute broken gears to abuse, which in turn is not warranted. These machines are mainly mass produced in China and obviously are very cheap. The labor and part (s) to repair are more expensive than replacing the machine.
If you do, look for a higher quality German machine i.e. Intimus, Olympia, HSM or Dahle. They cost more but they have a nationwide service arena and parts are always available.
Posted on Mar 08, 2009
  • 45 Answers
SOURCE: Our shredder is making a loud, grinding noise.
simply try resetting the machine. unplugging it waiting for about 30 seconds then plugging it back in, also is the unit mounted properly on the unit? It might be one of the gears that is not broken...if you have a warranty now would be a good time to call them as they will fix or replace the part for the unit.
Posted on Apr 15, 2009
Makes grinding noise and does not pull the paper in or shred. I have pulled out all bits of paper stuck between the teeth. I'm afraid this thing is toast
This type of shredder can get clogged so badly, the material has to be removed with a utility knife. This is especially true if someone has tried to shred coated stock or, worse yet, credit cards. The noise you are hearing is the mechanism bouncing over clumps of residue jammed in-between the grinding "teeth".
Apr 18, 2015 | Royal 1200MX 12 Sheet Strip Cut Paper...
Why is my ID Armor ID-XC200D making a horrible noise when I shred?
kkrenn641:
That "horrible noise" is probably caused by the shredder gears meshing improperly. If you disassemble it again and look carefully at the gears, you will most likely see that some are not mating properly... Usually the motor gear and the first idler gear that meshes with the motor gear. If those two gears seem to be separated a bit, or slightly mis-aligned look carefully at where the motor mounts, and you may see that the plastic "bed" where the motor is mounted has melted from heat from the motor. This is caused by using the shredder too long without letting the motor cool down. You may be able to shim the motor housing to realign the gears, if you have the patience!
Sep 13, 2012 | Staples ID Armor SH2836ID2836 Shredder
I have a Royal RL170MX shredder. It has started
Try putting some oil on a sheet of paper and then shredding the paper with oil on it.
If that dosn't fix it....take cover off....(with the unit unplugged.) and check plastic gears in drive train.
May 20, 2010 | Royal RL170MX Shredder
I was shredding paper when it started making a loud grinding noise and wouldn't accept any more paper. I've tried running it back and forth, but it only goes, maybe half way, either way, and it still...
This is a very common problem. Go out to the hardware store and buy some silicone spray. With the shredder unplugged, spray a good amount of the silicone inside all of the teeth and try to get all sides.
Plug it back in and work it back and forth a few times. It should work better with less noise now.
Jul 24, 2009 | Fellowes DM15C Shredder
Shredder makes a horrible sound when shredding.
Just put a lightweight shredder oil on some paper and shred the paper...do this a number of times this will get the oil down into the cutting shafts.
May 01, 2009 | Royal VF1000MX Shredder
Apr 10, 2009 | Medium Universal Office 38082 Shredder
REALLY loud grinding noise
If it doesn't work at all, there is a reset button for the unit. After it is reset keep the cutters lubed.
Jul 16, 2017 | Royal CIA 12X Shredder
Shredding no more
if the unit is pulling paper thru but not shredding your cutters have separated for some reason. If not pulling paper thru but machine is running you probally have a broken gear causing cutters to no longer turn you may hear a clunking or grinding noise or gear may be stripped if shredder sounds like it is spinning freely. Contact manufacturer for parts availability.
Nov 26, 2007 | Royal CIA 12X Shredder
91 people viewed this question
jasbo
jasbo
