Question about AOC LM720 17" Flat Panel LCD Monitor
Split screen on the monitor
My monitor is split into two pictures. i know most monitors have settings that allows you to do this. but its split in the most inconvenience of ways. it splits horizontally and shows half of the picture and when you go into the settings theirs no way of changing it. i'm wondering if this a simple wiring problem or a component problem.
5 Suggested Answers
  • 65 Answers
SOURCE: AOC 17"
NOTE: if image fold horizontally the section that you have to worry is VERTICAL!,in this case i suggest resolder the vertical (IC some TDAxxxx)and is a good idea to change it.
Posted on Jul 13, 2007
budmrtn
  • 11361 Answers
SOURCE: How to change the picture format on my monitor?
You should set your PC to the monitor native resolution for this monitor: 1440 x 900 @60Hz.
Here is the spec for your monitor: http://www.dealtime.com/xPO-AOC-919Swa1-Black
Posted on Jan 27, 2010
Testimonial: "very quick and simple answer!"
  • 87 Answers
SOURCE: image set up of screen is only half of the monitor
If you v-size is already at 100% then the issue is with the picture being sent to the monitor. Based upon what kind of input you have for the monitor there is a number of different ways to fix this. I will assume you are using the monitor with a desktop computer. If this is for XP, then there is a simple fix as follows, adjusting your display properties:
Right-click on your desktop background and then click on "Properties" this will open up a new window. Select the "Settings" tab, then drag the green arrow in the "Screen Resolution" field to the desired setting. Since you have a "widescreen set-up" you more than likely have a resolution where the first number is about twice the second number...they should be close to even to have a square image (bigger numbers show more detail than smaller numbers).
Hope this helps!
Posted on Jul 16, 2010
mercadoarvin
  • 384 Answers
SOURCE: hi, I have my macbook connected
Hi There and Welcome to Fixya.
Connecting a monitor to your MBP gives you more space to work on. You may want to check on the following and see if it was done properly :
  • Ensure physical connection - either mini DVI or mini DVI-VGA will work
  • Turn on the mirror mode by pressing "F7" or "Fn+F7"
  • Adjust the resolution of the monitor through the system preferences or the "Display status" in the menu bar
  • Put the macbook into "Sleep mode" to obtain the full (optimum) resolution on the AOC monitor
  • Keep the lid of the laptop open to access kybd and track pad
  • To boot the computer using the AOC monitor, turn on the computer and close the lid of the laptop at once.
Please let me know if this wont work.
Thank you for using Fixya.
Posted on Apr 09, 2011
How do i fix a split screen of my Toshiba c600d-t36b laptop
The quickest way to change the display output settings is to use the
display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order
(the last two options are available if an external monitor is
connected):
? Built-in display only
? Built-in display and external monitor (simultaneously)
? External monitor only
? Built-in display and TV (or other external video device)
? TV (or other external video device)
? External monitor and TV
? Built-in display and external monitor (extended mode)
? Built-in display and TV (extended mode)
? External monitor and TV (extended mode)
? Swap-Switch primary display between internal display
and external monitor when using extended desktop
Feb 12, 2015 | Toshiba Computers & Internet
How do I turn on split screen display
1. Have the windows you want on top of eachother open.
2. Right click the taskbar.
3. Click "Show windows stacked"
4. Presto! You're all done. Awsome, huh?
Nov 10, 2014 | Dell 23IN WS LED 1920X1080 1000:1 P2314H
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
I have a Dell 1704 FPVt monitor I use it in conjunction with an touch board with a monitor split cable. when I plug the team board in the dell monitor goes blank. It doesn't do this with the old m
Isolate the problem per above. Eliminate the monitor, split cable and software settings so that each, individually work. Then eliminate team board - do you have a spare?
It could mean sharing the monitor signal means weakens it so that one can display and the other does not work. Prove it with a different source computer. Don't know if buffer devices exist or how to increase input sensitivity.
Mar 07, 2013 | Dell 1704FPVs 17" TFT LCD Flat Panel...
I cannot get any sound through my tv from my acer ao531 notebook i have a picture but no sound
Try these options
1. Click on sound icon in Taskbar and make sure sound is up on HDMI volume. If this doesn't exist-
2. Start => Control Panel => Hardware and Sound. Under Sound tab click on Manage Audio Devices, right click on HDMI tab and enable. Or this: Computers have two seperate systems - one for video and one for sound.
The only computer (or laptop) connection that carries both video and sound is HDMI. If you do not have a HDMI/DVI connector on the back of your computer, then you will have to use the VGA-composite or s-video connectors to display your PC's output on an external monitor like an LCD TV.
On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two seperate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
Switching is performed using the fn keys on the keyboard (fn key plus the F2, F8, etc. function key with the display marking). You guys use single monitor mode until you figure out what your are doing. Select VGA-composite or S-Video.
Non-HDMI sound to your TV monitor or sound system must be obtained from your laptop's Headphone or S/PDIF jacks. Headphone is stereo and S/PDIF is 5.1 surround sound. Headphone is electrical, but S/PDIF may be electrical or optical (laser light). You must set the sound jack that you intend to use as the default on the PC control panel (Start/Control Panel/Sound).
None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video+sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
Mar 10, 2011 | Computers & Internet
Hello, 2 monitors running off d600 loptop one moniter not picking up windows wat is the problem help p'se
Hi. I hope this helps.
You need to open display properties, click on advanced, and make sure that the video adapter settings are configured to allow more than one monitor. some diplay adapters will only run on one monitor, some will allow cloning, where the same thign is displayed on both monitors, some allow span, which allows the total display to be split between the two monitors, and another setting to allow one to be the primary, and the second monitor for applications.
Also, check to make sure that on your power settings, you don't have it configured to power down monitors if not active. This can sometimes cause the second display to shut down when there is not an active signal going to it, and upon resumng it can cause the second display to not restart as it is supposed to.
Also, check each monitor seperately, having only one hooked up at a time, to ensure that the monitor isn't the problem. This is especially true if you are using flat screen monitors. They are notorious for working one minute, and the next they just quit. Almost all flat screen monitors..i.e. lcd, plasma, and dlp have capacitors that precharge to energize the screen, and those capacitors are quite prone for going out without warning.
I hope this helps you out.
Jan 23, 2011 | Dell Latitude D600 Notebook
Cant get any sound on tv
On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two separate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video + sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
Please let me know if you have any further questions or concerns.
Thanks.
May 07, 2010 | HP Compaq Presario C700T
When i connect my laptop to the tv i get sound but no pic.
Feb 11, 2010 | Dell Studio 1537 Laptop
Lcd screen is split howing the whole picture
Check the same in bios if it gives the same issue, it is something to do with graphics card. You may try to disconnect the monitor from the computer, it will show a message, if the message also is split then its a monitor issue.
Regards,
Shrey
Oct 09, 2009 | Westinghouse LCM-19v1 Monitor
AOC LM720 17" Flat Panel LCD Monitor Logo
140 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
