Question about Zynga Texas HoldEm Poker
Open widescreen! Click here to play in fullscreen and get the big picture for an even better gaming experience. Click again to get small.
  • suela Jan 01, 2013
    CA3 please open my pocker i have message code:CA3
    .CODE CA3 please open my poker i have message resent code
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
Mac
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    _
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 | bigfishgames.com
How do i get the viewfinder to show fullscreen. At the moment there are 2 black strips down each side in "iauto" mode. When i first had the camera it was fullscreen. Thank you.
The LCD screen on the Olympus SP-800uz camera is widescreen (16:9).
If you set the camera to take pictures in (4:3) ratio you het the black sides.
Solution:
Select a Widescreen Image Size (see the manual page 30) by selecting one of
the available Image Size settings 16:9 (L) (4288×2416) or 16:9 (S) (1920×1080).
Jun 12, 2011 | Olympus SP800UZ Digital Camera
What software needs to download for playing fullscreen video in Samsung corby plus?
You don't need any software I guess. When you open media player in your phone, click option and see if there are any fullscreen setting in it.
Several phone with auto rorate even have easy way to make video played full screen. When we play video, just move the phone from portrait to lanscape mode, round 90 degrees, and the video will automatically full screen
If this helpful, RATE please !
Jan 20, 2011 | Samsung B3410 Cell Phone
Please help me. I am trying to watch Avatar on my LG Dvd player. It works only in Fullscreen and will not play in Widescreen.
Check the dvd menu should have a choice to pick widescreen or fullscreen.Not,at the begin of the movie will have paragraph or audio anouncement it said it playing fullscreen to fit ur tv.
May 04, 2010 | Televison & Video
Picture format to large
There should be a format button on your remote to change between widescreen & fullscreen as well as the zooms. May say format or aspect. If not on remote look through your menus. Make sure which ever u select u do not choose a zoom. This will cut of top & bottom of picture
Apr 06, 2009 | Televison & Video
HALF OF THE SCREEN
Are you referring to the black bars that show above and below the movie? That's normal, it's called widescreen aspect ratio.
If you don't like that, you want to buy/rent fullscreen movies.
Widescreen is 6:9, fullscreen is 4:3. (Square versus rectangle)
Mar 19, 2009 | Durabrand DVD-1002 DVD Player
Help
how are you connected to your tv? if your are connected in HD mode (hdmi cable) you will only get a 16:9 picture... SD mode (AV cable, S VIDEO cable, Component AV cable or SCART) will transmit a picture of 16:9 or 4:3 (4:3 being the old 'square screen' mode)
Oct 01, 2008 | Sony Playstation 3 (PS3) Console
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Zynga Texas HoldEm Poker Logo
59 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Corne Viljoen
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
