Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Hoover spinscrub water keeps coming our
With out pulling the trigger to dispense water its coming out all by itself, how to fix it
  • lemmings88 Jan 22, 2009
    The o-ring is there and everything looks good but water still coming out, oh no I love this machine
  • 294 Answers
Check the machine where the water tank is installed, you will see a pipe stem this stem should have an o-ring gasket on it. also look at the plunger in the tank for proper seating.
Posted on Jan 20, 2009
How can I fix my Hoover spin scrub 50 solution trigger? It is not working.
Hey there! Sounds like you have no tension in your trigger. This could mean a problem with the trigger spring or control rod in the handle. Try reassembling the handle. Remove the two handle screws and slide the handle up and off. Inspect the control rods for damages. They should be the same length. Make sure they are pulled down as well. Reassemble the handle. If the trigger still has no tension but the cleaner dispenses from the hose, a replacement handle may be needed. To replace the handle, follow the link below.
Search Results
Hope this was helpful!
Jun 11, 2014 | Hoover SteamVac Spinscrub 50 Carpet...
V -024A WILL NOT DISPENSE SOLUTION
Try cleaning spray tip in CLR. Hard water?
Apr 14, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover SteamVac F5914-900 SpinScrub... The last time I used the hand tool attachment, it worked fine. Just tried to use it again, and now I only drips of water will come out of the hand sprayer,...
The brushes can be turned off on most of them via a switch on the hood. There shouldn't be water coming out onto the floor unless you are pulling the trigger at that top. You probably broke this when attempting to use the tools.
http://www.vacuummedic.com/product.php?id=231
Sep 23, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Iam trying to use the upolhstery piece. Iam squeezing the button and no cleaner is coming out. Iam using by hoover steam vac deluxe spin.
Confirm that the hose is correctly connected to the clean water supply. If so, then remove it and, with the trigger operated on the hose, try to blow into the water feed connector. If you cannot pass air, the feed tube in the hose is clogged and must be cleaned (either by running faucet water into the brush end (with trigger pulled) or by using compressed air....
Nov 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
The machine turns on and the indicator seems to be spinning but the water is not moving.
Operating the trigger does not dispense water into the spinning brushes - is that the problem?
If so, remove the clean water tank and look in the opening behind the black grommet that seal the water tank. Operate the trigger and look to ensure that the valve is operating (moves downward when trigger is pulled). If it does not move, the trigger shaft is stuck or broken and will need to be repaired.
Nov 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Water and shampoo run out with the trigger in the off position
From your description, you have a problem with your one of the solenoids that may be stuck open. this would require a shop repair.
Nov 30, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Water and cleaning solution will not dispense unless I hold it for a while
check the belt on the pump it should be a cover on the side pull the belt to the pump if its glazed replace if not then clean the shaft old soap may be on there.
Oct 03, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
I need the nylon part that dispenses water when you press the hose trigger, for the stairs and upholsterly tools.
If you are talking about a piece in the handle of the hose, you may have to replace the whole hose asm. part number 90001336. A repairshop should be able to see if you can just the piece you need, if it is available by itself.
Apr 09, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Most likely will have to replace either the nozzle valve or the hose comes complete, so if the nozzle pieces are available, then replace the complete hose asm.
Sep 06, 2006 | Hoover V1 SteamVac SpinScrub Vacuum
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
178 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
