Just need to know how many watts is rz-8300 av Sansui
What is the wattage when it is used as Stereo and 5.1?
robotek
  • 1512 Answers
SOURCE: Sansui RZ 8300 AV Receiver
Hi curtmalm
First, do a rest on the unit by disconnecting from the wall overnight. Then fire it up again to see if it recovers. Let me know here how you go.
regards
Graeme
Posted on Apr 14, 2008
SOURCE: Sansui RZ 1500 II-Manual
i have the same problem but my receiver doesn't change sources and its blocked on the last station llistened. the problem appeared when i washed the face of the receiver with a special spray. i think that i have done something very wrong like a short cut in the command processor. any help, please?
Posted on Nov 08, 2008
SOURCE: Sansui
I need a card with SMD ICs located on the circuit board of my sansui RZ6800 AV Reciever.(its a digital card with function IC and many more SMD components)
Posted on Apr 30, 2010
dunnbiker
  • 8546 Answers
SOURCE: i have a sansui stereo
Remove the fuse cover with a flat screwdriver, then pull the surrounding circular black plastic piec straight out and reorient it to show the desired voltage, then plug it in, insert the fuse and cap.
Posted on Jan 18, 2011
dunnbiker
  • 8546 Answers
SOURCE: How do I connect Subwoofer
You could refer to the instructions presumably available for the unnamed sub. THAT would determine the methods it can use.
Posted on Aug 17, 2011
Can I use a 412 guitar cabinet in a vehicle as part of the stereo system at what type of amp what I use to push that
You would want an amp at least the wattage of the speakers, I would go double the wattage, say 800 watts and fuse speaker so as not to blow them. This way you have power to spare if you upgrade.
press the helpful button
INSANE Car Sound Systems
Custom Car Stereo Sound Systems
24 000 WATT Car Sound System PART 1 of 2
How To Design Car Audio System
Jan 23, 2016 | AMP Music
SANSUI STEREO AV RECEIVER RZ -2605AV NO SOUND
Sansui RZ-2605 A/V Receiver no sound
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 07, 2012 | RCA Audio Players & Recorders
How do I connect Subwoofer in sansui rz 5200 av model receiver?
Aug 17, 2011 | Sansui RZ-5200AV Receiver
I have a sansui stereo av receiver rz 7000 from 1990 which works on 110 220 230 volts and the receiver has a voltage selector on the back - I need to understand how to move the selector from 220 to 110...
Nov 24, 2010 | Sansui RZ-8150AV Receiver
Demension 8300 no power up
All you have to do is replace the power supply, and the computer will come on. What has transpired, is the power supply went out, and the people you received the computer from, didn't know that. Too bad, as this is a cheap fix, and easy to do.
Do you have another desktop computer, that you can borrow a power supply out of for a test?
The Dimension 8300 uses the standard ATX power supply, that about 98% of computers out there do.
The Dell Dimension 8300 uses a Pentium 4 processor.
Uses either DDR Sdram at 333MHz (PC2700) or DDR Sdram at 400MHz (PC3200)
Maximum TOTAL Amount of ram is 4GB
Maximum Amount for EACH ram slot is 1GB.
Motherboard chipset is Intel 875P
Has an AGP 8X slot for a graphics card. (Remember that it's AGP 8X. This is the best version of the AGP style graphics cards. They still sell them)
Has four PCI slots.
Uses an IDE harddrive. (IDE is also referred to as EIDE, ATA, and PATA)
Has either a 250 Watt power supply, or a 305 Watt power supply. Back when this computer was made, power supply's actually only put out 70 percent, of the stated maximum wattage. Not the computer manufacturers fault, it was the power supply manufacturer. (The power supply's are made by somebody else, just like all the parts are for a pre-built computer) The power supply manufacturer had the tendency to 'fudge' the Wattage rating up a little. Made the power supply look better.
http://support.dell.com/support/edocs/systems/dim8300/sm/specs.htm
A computer will only use the power it needs, and no more. I don't care if you put a 10,000 Watt (Exaggeration. They don't make them for a personal computer) power supply in your computer,
if it only needs 100 Watts, it only uses 100 Watts. (Like surfing the internet)
I recommend this $30, reliable, decent power supply. It's a 350 Watt unit,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3255390&CatId=106
How to install a power supply,
http://support.gateway.com/support/manlib/cmponts/Process/8508750/08750c01.htm
(From Gateway.com/Support)
Apr 17, 2009 | HP (D7580-60003) Motherboard
Sansui RZ 8300 AV Receiver will not turn on flicker on and off. Power turns on but when the standby button pushes in it just flickers on and off.
Hi curtmalm
regards
Graeme
Apr 14, 2008 | Audio Players & Recorders
Sansui
Sep 01, 2007 | Audio Players & Recorders
No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Feb 01, 2007 | Sansui RZ-5300AV Receiver
154 people viewed this question
 Grubhead
Grubhead
