Question about Krups Dolce Gusto KP 1009
Can not get machine to make the drink
Have followed all steps to make drink the pump comes on but it doesnt make the drink
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
Go to the bar and have them make you a drink
Posted on Jan 02, 2013
How can i loose weight
if you are asking how to lose weight while eating salad lettuce fruit and vegetables- the answer is to lower the caloric intake and increase the activity you do, this will help burn calories resulting in a loss of weight. also portion control is important.
Jan 18, 2015 | Cooking
When I turn on the steam function a steady stream of water comes out fow a few seconds and then diminshes to a few drops when the pumps comes on every few seconds , but no steam comes out nozzle. I ha
This is similar to my Saeco. i only drink black coffee so the steam function is very rarely used. When i went to use it recently got same as your description. this then set a 'blocked' code on computer which meant NO COFFEE! EEEKKK.
I used an old soft drink bottle as a resevoir to operate the machine with covers off so i could see an issues. I started at the filter , blew that out with compressed air. then hoses...do 1 at a time ...tank to filter, filter to pump, pump to heat exchanger, heat exchanger to spout (watch this one as it is steam!)
after a thorough strip and assemble i descaled and was good to go. now i make sure to use steam at least once a month.
Feb 11, 2014 | DeLonghi EAM3400 Espresso Machine
What flavors do meal replacement drinks come in?
Meal replacement drinks typically come in the following flavors:
Chocolate
Vanilla
Strawberry
Chocolate peanut butter
Feb 04, 2013 | Health & Beauty
I have a bunn ultra 2 flat lid ice machine, manual failed to come with the machine. it needs cleaning, the 'clean due now' is always on the screen, followed the info on the side of it to clean and even let...
Can go to the Bunn website.Go to commercial section,then manual index and then specialty drinks.You can find :Illustrated parts,operating service,service,repair and programming.
Oct 16, 2010 | Bunn Black Flat Lid Ultra 2 Ultra Gourmet...
Clean pump
If this is a Whirlpool Duet model washer, the following link explains step-by-step, how to access and clean the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If this is not the model washer you have, or if you require additional assistance, please post back and let me know. I hope this is helpful to you.
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer doesnt drain water i already checked pump it washes but when it comes to spinning and draining water it just doesnt work
follow your drain line back into the machine, it will connect to a plastic "box" at the bottom of the machine. Can't remember the correct nomenclature for this part but it creates a type of venturi effect that helps eject the water (speed it up) on out the drain line. If that is plugged up with debris it will not drain a bit. Very easy to replace.
Dec 30, 2009 | Washing Machines
F21 keeps coming up on the washing machine
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
Machine locks up and code f21 comes up
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Dec 25, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Doesnt work when its warm
The pumps in these are low resolution pumps and don't seem to take a lot of stress. We ran the same machine with three groups 362 days a year. You probably need to replace the pump. You should watch your gauges and be pulling 9 - 10 bars when pulling a shot. The top side of your gauges is water pressure coming in. Sounds like a new pump. Good luck.
Nov 18, 2006 | Nuova Simonelli Premier Maxi Espresso...
Krups Dolce Gusto KP 1009 Logo
313 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
