Question about ASUS P5PE-VM Motherboard
Why is my monitor so slow to show image after boot?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 2,226 Answers
Hard drive maybe slow defrag it
Posted on May 27, 2014
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
Compaq 615 laptop just hung, i removed the battery then tried to boot again but showed nothing
Hi
Not enough information.
It would be helpful to know if this machine running XP, Vista or Win 7.
Can you hear the CPU beep during boot?
Do the lights come/blink on on the front of the laptop?
All this information is important if you want accurate advice to help solve your problem.
If you have a desktop PC monitor available, connect this to the laptop's VGA port and press the Fn (function) key simultaneously with the F5 or F6 key (the key showing 2 monitors) while booting, to send the image to the external monitor.
If you can see images on the external monitor, then your laptop may have (in ascending order of seriousness/cost of repair), an LCD panel inverter fault/failure, a cold cathode backlight fault/failure, an LCD panel fault/failure, a graphics card fault/failure, a motherboard power management system fault/failure, a motherboard fault/failure.
Sorrry to not be able to be more precise.
Hope this helps.
Aug 02, 2011 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
My monitor shows image for about 3 seconds then goes black.
sounds like its set in the bios to boot on a second video card. At startup hit f2 (usually) then find the first boot setting and make sure its booting to the correct card. I
May 08, 2011 | Princeton Digital Computers & Internet
I turn on my imac and it makes the boot sound but the screen doesnt turn on what should i do?
Attach an external monitor to the port on the rear of the iMac (requires a mini-VGA to VGA adapter). If the external monitor shows image, then you have a bad inverter or LCD panel, or a disconnected display cable. If the external monitor shows no image, then it is something else, and whatever it is will probably require a logic board replacement, which is not cost-effective in a machine this old (unless you have an unusual source of used parts).
Oct 25, 2010 | Apple iMac G4 Desktop
My monitor shows image immediately when switched on but just as soon the image appears the screen of the monitor goes dark after that need to off/on the power switch three to four times before the image...
Please restart your computer and tap the F8 key as soon as you see something on the screen. You should get the advanced boot menu. Select Safe Mode from the list.
Let me know if you were able to boot to safe mode.
Jun 18, 2010 | Dell E193FP 19" LCD Monitor
Image for first 3 secs... light still on green
correodemie, Your ACER AL2016 will need to have it's "switch-mode-power-supply/CCFL inverter supply" trouble shooted and repaired. DIY repair cost less than $30. Out of warranty service $35 to $75, more if circuit board replaced. Read my and other techs FIXYA profiles to discover all the options you have for your BLACK screen symptom. Follow the links to other web sites for even more useful info. DO THAT before you do anything else. 12fixlouie
Feb 03, 2010 | Acer AL2016 W 20" TFT LCD Monitor
No picture, monitor won't show anything black screen. Monitor was working fine put it on another computer and it won't show images. Could it be part of the power saving system? Is there a reset button?
Does the monitor show absolutely nothing, not even when first turned on? In that case maybe the cable could be defective or connected improperly, or the new computer might not be compatible (or set to output to, say, digital port, while you've got a SVGA monitor). In that case you'll need to connect a working monitor for the time required to reconfigure the computer.
If the image does appears at boot, or resetting the computer, and then disappears, it could be that the new computer is set to a resolution which is too high for the monitor, which goes in protection mode and effectively turns off. Again you'll have to gain access to the computer (maybe booting in Safe Mode) and lower its video resolution to something the monitor can handle.
Hope this helps, have a nice day
Jan 12, 2010 | Sharp LL T17A3-B 17" LCD Monitor
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
Gateway FPD1530 loses image shortly after powering up.
try booting into safe mode. press F8 while the computer is booting. see if everything stays normal. It should tell you that it booted into safe mode. Once there, change the resolution or the frequency of the display(also known as the refresh rate) by right clicking on the desktop and selecting properties. Once there, click the tab all the way to the right, it should give you color quality options and resolution options. At the bottom, there should be an advanced tab. Depending on our video card this menu can be different from others. Look in that new window for and option to change the refresh rate or the frequency. The value will be in xxx hertz. try setting it to 60 hertz.
Jan 31, 2009 | Computers & Internet
ASUS P5PE-VM Motherboard Logo
160 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
