When power button is switched on, the following happens: on light flickers, there is a clicking sound and no picture
Model tstv29
  • 933 Answers
I would suspect leaky capacitors on the power supply board. Take off the back cover, and check the capacitors on the power supply board. If you find any that have bulging tops, they will need to be replaced with the same uF of capacitance, at least 105 degree C temperature rating, and with at least the same voltage rating.
Posted on Jan 01, 2013
SOURCE: power on no picture
dougarm
Just unplug the TV wait a a short time, plug it back in and turn on right away. This has worked for me.
Posted on Jan 19, 2009
dsacco86
  • 1077 Answers
SOURCE: i have no power light. I hit the power button and
First, I would try leaving the TV unplugged for an hour so the TV can discharge and reset itself.
If this doesn't work, it maybe something simple like a blown fuses inside the TV that needs replacing. Radio Shack or some electronic store will carry the fuses.
If the other two ideas doesn't solve it, we're talking about a power supply board related problem. I can actually look at your TV over the internet. But, the most common problem with flat panel TVs are the power supply board for the screen itself and the main power supply board for the rest of the TV. Commonly a bad capacitor or transformer will be on the board.
If you have some electronic experience and want to repair it yourself, you can sometimes find a Service Manual for your TV over the internet. Normally, costs less than $20. It will have diagrams, schematics, and part number list for the TV.
Posted on Aug 09, 2009
SOURCE: I have a Sony Bravia KDL-S40A12U have had 3
if you cant fix the problem and need to buy another tv, let me know if you have the stand the tv came with. I would like to purchase it from you
Posted on Aug 18, 2009
SOURCE: power button comes on but no sound or picture
CAN YOU TELL ME THE PART # ON THIS BOARD
Posted on Mar 07, 2010
ginko
  • 19396 Answers
SOURCE: Philips plasma T.V. model BDS4231R/00 Cassis
Hi.
If the TV keeps shutting down and goes in standby, then the TV is going on protect mode after detecting a malfuncion.
When this happensthe TV gets shut down to prevent further damage to internal components.
Before calling support ensure that you have followed the indications here Why my TV does not start up and remains in standby.
Troubleshooting basically consists in leaving the TV unplugged to drain power completely and discharge internal circuits. Instructions are for a DLP, but procedure is the same with any TV, even plasma TV.
The best way to contact an authorized technician is by ringing the number listed on the owners manual. Alternatively try Fixya directory here:Fixya directory- Consumer Products Repair
Try first the troubleshooting proposed in link above. If that does not work, ring customer service.
Regarding the rpair cost, this depends on the part that is defective. A common fault is the power supply, but this is not necessarily the problem.
If you are a repairer,testing willl start from PSU, following voltages on main board and testic diagnostic points listed on service manual. Here the service manual: philips slc4.3e - Service Manual
For parts try Partstore or ShopJimmy .
Regards.
Ginko.
Posted on Aug 17, 2010
Not turning on
It would help to know the brand and model of the camera. If all you want is to get the pictures off, you can pull the SD card or connect it. That should get the pictures off.
What happens when you press the power button? Does anything happen (lights go on, screen flickers, error message, ...). I assume you have tried putting new batteries in.
Jul 27, 2016 | Cameras
Why does my camera not capture any picture? Whichever mode I use, it does not capture any picture regardless of how many times I click the button.
Flash flicker is the camera trying to get enough light to focus, It occurs when you press the shutter release part of the way down.
Try the same thing outside, ensure you press the shutter real ease all the way down. If it still does not fire, switch the lens to manual focus (sliding switch on the side of the lens, move from A to M) If the camera shoot then, the camera is struggling to auto focus.
Feb 23, 2015 | Canon EOS 1100D / Rebel T3 Digital Camera
Flickering headlights, tailights , and dash lights
Sounds like just a bad switch, replacing it should solve the problem. however, check the ground strap that is attached to the firewall to give all the body electrics a ground. they get dirty and need to be cleaned,
Nov 03, 2013 | Dodge Cars & Trucks
When i boot up power button on monitor goes on off resulting in flickering picture.
hi look for a bulging or bad electrolytic capacitors in the PSU board which cause the output voltage drop, usually 1500 uf/ 16v.just replace those bad cap then it will resume to normal operation good luck thanks for consulting through fixya.
Jun 23, 2012 | Computers & Internet
My lg 37 inch lcd works fine for five minutes then a big popping sound happens , i loose picture and sound but power remains, after this it will either keep popping or picture and sound will return for...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 17, 2011 | LG 37LC7D 37 in. LCD HDTV
My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
Nov 20, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Lens is out, Camera won't turn on, power light flickers
Take battery out and clean contacts with an eraser on the end of a pencil.
Then try.
What stage is the lens - all the way out or partway?
OPut a finger on the lens barrel - do not puch it - this will ruin the drive- switch off the wieght of finger may be enough for the lens to get into gear..
Jul 13, 2008 | Samsung Digimax S500 Digital Camera
Washer Clicks
The main drive motor has a relay switch on the side of it. The clicking and power flicker along with only the first couple of cycles are a good indication if a bad motor relay.
Feb 19, 2008 | GE WBSE2090A Top Load Washer
No picture, no sound?!?!
This could be a number of things. Your lamp could be bad or it needs to be reseated to the ballast. The lamp is trying to light and it will make the ballast flicker (that is the clicking sound) or your ballast is bad and it needs replaced (it will flicker and click too). Or your color wheel is broken and it will make a clicking sound when turning. If the color wheel is not spinning or broken it will not light the lamp. No lamp no picture.
Dec 12, 2007 | Samsung PCN5425R 54" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
