Question about Haier HWR08XC7 Air Conditioner
E4 error with 12btu logik split air conditioner
  • Marius Grundlingh Jan 04, 2013
    Hi guys I found the problem it was the Internal fan motor that was not turning, it is on the indoor unit and just remove the cover from the indoor unit and replace it. Thanks for trying.
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
I have a waves airconditioner. Its not cooling well n after some time show e4 error. How to remove the error? Plz help.
http://acerrorcode.com/tcl-air-conditioner-error-codes.html
This was googled: waves error codes
It showed a page in "images". Stated
"System abnormity" I think. Page was blurry.
Call a tech! Mini splits can be a troubleshooting nightmare! I think its a Fujitsu unit. It would help, and may save you some $$, to call around to find a technician who has worked on mini splits. And maybe find them a 1-800 # that is their tech support # before hand, so if the tech needs it, you have it. E4 is a vague description for a fault. Make sure you have cleaned air filters, cleaned o.d.coil (turn off power at breaker 1st). Changed batteries in remote. Work safe!
Jun 20, 2015 | Heating & Cooling
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Error e4 sir air split unit
We have a SirAir Split unit Airconditioner, It's not cooling and shows e4 error.
Feb 27, 2013 | Heating & Cooling
E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
May 07, 2009 | Heating & Cooling
SPLIT AC
PROBLEM WITH THE INSIDE FAN MOTOR
Sep 27, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Haier HWR08XC7 Air Conditioner Logo
172 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
