Question about Dakota 2786-6 Wristwatch
Lose or gain time?
I recently purchased a Dakota (clip-on) belt watch and from time to time it is exactly 1-2 hours behind - once it was 1 hour ahead (?). In the beginning I thought I might have set it wrong, but then on 2 other occasions the time was not accurate. The minutes seem to be accurate, but the hours are not. Does this happen when the battery is low? Or is it something mechanical?
  • David Shaub May 11, 2010
    Are you in a "Daylight Savings Time" zone?
  • 4 Answers
We are sorry to read of the trouble you have experienced with your Dakota watch. The problem you have described is typically a mechanical issue that requires a movement overhaul completed by our repair department. Depending on the details of your purchase (date, place of purchase, receipt, etc) this service may be covered under warranty. To determine how to submit your watch for repair, please visit your nearest Dakota Watch Company store location, or contact our Customer Service by email at customerservice@dakotawatch.com, or by phone at 1-888-459-0404. Thank you!
Posted on May 21, 2009
Cannot adjust time on ohe atomic clock
Let it adjust itself, usually at next transmission time WWV in Hawaii reset several times a day every four hours or so.Thats my experience.
May 13, 2017 | ATOMIC Watches
I need to change time on my g910 watch that I purchased from a cruise the millennium I need to put 2 hours ahead to the Australian Melbourne time Thanks
no problem
when you get to your destination just set it to local time
Australia has the same 24 hours in a day time measurement as anywhere else
Oct 21, 2016 | The Watches
I think i have an old one,but i have a two button illuminator watch. recently daylight savings began and im an hour ahead how do i change the time?
just reset the time as if the watch stopped
daylight time is not a special time just an hour earlier or later
Nov 08, 2015 | Casio Illuminator Watches
My g-shock ga-110c-1a hour hand is 6 hours ahead. The digital time is correct but the hour hand is six hours ahead. If i set the time at 6:00pm the hour hand will move to 12:00. the minute hand is fine, i...
go to support page on casio. and get your manual. youll probably gonna look for a 3 or 4 digit number located at the back of your watch. once you got the manual. go to page 4. and follow the steps of "Hand Home Position Correction". that should fix it.
i also have ga 110c and i have encountered this issue
Dec 29, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
How do i change the hour? Only goes 6:40 and 5:40. cannot go back to 4:30 or ahead 24 hours.
I think you are changing from DST (daylight saving time) to local mean time.
Presumeably your problem is that the watch is not telling you the local time.
As the watch is radio controlled you can only change the time by choosing the location setting, so that the watch knows where you are.
Press the "mode" button to select the location abreviation and use other buttons to change to your local city.
When you have set the location, press the mode button to return to normal operation.
Jul 16, 2010 | Dakota Watch Company Radio Controlled...
The watch will show incorrect time within hours of
Usually this is a faulty battery - make sure you go to a reputable jeweller and have the battery changed. Even somewhere like Kmart will only use decent quality batteries.
I bought batteries off eBay once that were very cheap, and I had this problem all the time. Now I only buy Energizer, Duracell, etc.
Nov 25, 2009 | Freestyle Watches
Omega Seamaster gaining about 10 minutes per hour
Hi honestfunguy. Take it back! Omega watches are usually guaranteed for 2 years or even 3 years (Co-axial escapement), so you should not have a problem getting it repaired under warrantee. No way should it be be gaining (or losing) 10 minutes per day, let alone 10 minutes per hour. Could be any number of things, from a broken mainspring to problems with the timing regulator, but they are very complex watches and should not be looked at by anyone apart from Omega whilst in warrantee, otherwise you'll probably void the warrantee. Hope this helps; Eagle58
Jun 07, 2009 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
Mar 09, 2008 | Timex Sports Ironman Triathlon 50-Lap...
Dakota atomic wrist watch sold by National geographic
s1 is the top button and s2 is the bottem button
Feb 20, 2008 | Dakota 2786-6 Wristwatch
Dakota 2786-6 Wristwatch Logo
231 people viewed this question
Top Dakota Watches Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Dakota Watch Expert? Answer questions, earn points and help others
