Question about IBM Lenovo ThinkPad X40 Notebook
Lenovo thinkpad plugged in not charging is there a problem
Battery currently at 44% on enery save
    Novelist:
    Champion:
  • 233 Answers
Laptop plugged in not charging:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the IBM ThinkPad X40 power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Posted on Jan 03, 2013
2 Suggested Answers
aaarwind
  • 141 Answers
SOURCE: My Lenovo ThinkPad T61 has
Try to start the laptop without battery (remove the battery and plugh the adapter and switch on) if problem persists. Take it to the Service center , Becose your laptop motherboard may have some kinda SHORTS. best of luck
Posted on Jan 22, 2011
How do I replace the battery
Battery recall - Lenovo Support (US)
support.lenovo.com/us/en/documents/hf004122
LenovoJul 9, 2015 - These batteries were manufactured for use with ThinkPad notebook ...batteries with new notebook computers or as optional or replacement batteries on the... Which ThinkPad notebook PC models are affected by the recall?
Remove the battery pack - Lenovo Support
https://support.lenovo.com/documents/migr-46510
LenovoJun 17, 2014 - Install charged battery; Slide the battery latches to the locked position. Slide the battery latches; Turn the computer over again. Connect the AC ...
Nov 19, 2015 | Lenovo ThinkPad Computers & Internet
Why plugged in not charging
Is the computer at full charge (or at least 90%) prior to the attempt to charge it? I know that my Lenovo is set to not charge from 90% in order to keep the battery from overcharging.
Jul 02, 2014 | Lenovo ThinkPad T410 Notebook
Plugged in but not charging
How old is the laptop? Batteries only last for so long. Try this:
1. Remove the battery from the laptop.
2. Plug it back in.
3. Try to charge.
4. If still does not charge, replace battery.
Jan 19, 2014 | Lenovo ThinkPad Edge E531 Laptop
Battery plugged in , not charging ?
please check adapter got power output or not ?
if got then maybe battery spoil or notebook cannot charge.
Oct 24, 2013 | IBM Lenovo ThinkPad X201 Notebook
Plugged in, Not Charging
first thing you should check is the AC Adapter voltage output and Amperes that your computer requires.
if all ok, try this:plug in your AC adapter to your computer in a switched off position. wait for an hour or two then turn on your pc and check whether the battery has been charged or not. if not, then the battery is gone but if it's been charged and drains so fast while the computer is on then you should buy a new battery.
Mar 06, 2013 | Lenovo ThinkPad SL410 Notebook
Lenovo ThinkPad T520i Battery
Have you check your Charger for Proper Voltage? Is it Providing Proper Voltage to your Laptop? Check it First.
This Problem can Happen due to bad Charger or due to the Charging IC not Functional properly, which is located on the Board of the Laptop
Aug 11, 2012 | Lenovo 423947U - Thinkpad T520I 423947U...
My Lenovo ThinkPad T61 has the indicator light that it is plugged in and that the battery is charging. The computer is also off. But every time I press the power button to turn it on the both lights go off...
Jan 22, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
Bought a new ac charger for the laptop and tried to charge it up ,critical low battery error keeps coming up and computer switches off
replace battery, as long you adapter plug in indicator work charging also work so only battery not accept charging.
Apr 04, 2010 | Lenovo ThinkPad R61 Notebook
IBM Lenovo ThinkPad X40 Notebook Logo
130 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
