Question about Cobra 29 LTD CB Radio
How do i find and replace the finals in a cobra 29ltd classic
The fuse keeps blowing when i hook up the radio, replace the fuse....still the same problem
  • Spank Wertz Jan 26, 2013
    has anyone ever hooked the power up backwards ? if so you prob popped the safety diode.i would look into that before i went and tried to change finals
    Novelist:
    Champion:
  • 211 Answers
The protection diode (a black, tub looking devise) hooked to the positive power wire near the back of the radio, is most likely your problem. Check to see if any doides are shorted by using a Volt/Ohm Meter by checking for a short. For more imformation or help, email me at wyoed1@aol.com.
"Original Radio Man"
Ed
Posted on Feb 13, 2013
Communicomm
  • 90 Answers
SOURCE: COBRA 29 NW LTD CLASSIC
Capacitor C-82, which connects the output of the driver to the input og the final, is leaky or shorted, putting +12 volts on the base of the final, which blows it immediately.
Posted on Jul 20, 2008
Benimur
  • 6966 Answers
SOURCE: Cobra 29 Ltd
Appreciate the direct "Ask Me" again.
The initial posting would still hold true, best would be:
  • remove TR18;
  • replace 2SC2069 with 2SC1969; and
  • adjust L12, 13 & 14.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 08, 2008
  • 773 Answers
SOURCE: i want talkback on my cobra 29ltd classic radio
Open the case on your radio. Solder a 100 ohm resistor between the pa jack and ext speaker jack. You can add a switch if you like to turn it on and off. The lower the resistance, the louder the talkback.
Posted on Apr 25, 2009
  • 773 Answers
SOURCE: Cobra 29LTD CHROME low tx no mod, rx good low Vol, talkback good
1 why would you change the finals?? Have you checked you antenna? How are your SWR's? Crappy antenna's cause a lot of problems.
Use an external meter to see what the SWR is, and see what the output is PEP. If its low, then there is something wrong. If it is High, change the mic and turn up the dynamic all the way.
Next. Have you been messing around in there?? Tryin to get more wattage? You turned VR4? If you thought you were turning it up by turning it all the way to the right, you turned it all the way down. Turn it all the way to the left.
Posted on Jun 17, 2009
kd7och
  • 10 Answers
SOURCE: HOW DO I SET THE
http://www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/index.htm
29LTD ST Owners Manual
Posted on Jan 13, 2011
What size fuse is used in COBRA 29LTD CLASSIC radio.
First question should be, what happened to the last one? If the fuse blew on you, you need to find out why. If it was just missing when you got the radio...
That said it is surprising that the manual doesn't state this value directly. However, it is a 4W transmitter and the manual I referenced states that you should connect to an "accessory" fuse for mobile installation. My car has a 10a fuse in that position but a 3A slo-blow in the power wire's inline fuse holder should do the trick. (The main reason for using the "Accessory" fuse is for operation with the engine off, but not battery drain unless the key is inserted.) Another clue for my SWAG is that for a "base station" installation, the manual recommends a 12Vdc power supply that can deliver >2A... So I think we are in the ballpark.
If you have lost your original manual you can get a replacement from the Cobra support site here:
https://www.cobra.com/support/product-manuals
V/R,
Veg
If a train station is where the train stops, what happens at my workstation?
~Author Unknown
May 04, 2016 | Radio Communications
Cobra 29ltd schematic dale earnhardt
It's the same as the standard 29LTD Classic. Here is a link to the schematic. http://www.cbtricks.com/radios/cobra/29ltd_chr/index.htm
Aug 24, 2014 | Radio Communications
I have the Coba 29LTD Classic when i key up my meter do not move . i can git incoming but can not git out
did you ever check the swr's.. if they were high may have blown,. the final rf transistors.
Jan 23, 2011 | Cobra 29 LTD CB Radio
Where and what does the fuse look like for the Cobra 29LTD Classic, and is there a fuse #.
Hi, my name is John. Welcome to Fixya. You should find the fuse inside the fuse holder located on the red wire going to power source. Push and turn counter-clockwise to expose the fuse. the number and amps are stamped on the end of the fuse. Thanks for choosing Fixya.......John
Oct 27, 2010 | Cobra 29 LTD CB Radio
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Help with cb radio
Hello there
here is a link for the scematic ok?
best regards michael
  1. Cobra 29LTD ST, 29WX ST 29LTD ST Owners Manual. 29WX ST Owners Manual. DIAGRAMS. 29LTD ST Schematic Diagram ... WX Schematic Diagram. 29LTD, 29LTD ST, 29WX ST Factory Service Manual ...www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/index.htm - Cached
Sep 15, 2009 | Cobra 29 LTD CB Radio
CB keeps blowing fuses
There are a few common reasons the fuse keeps blowing:
1. The transmitter final transistor is bad, it usually is directly connected to the 12v source and not switched by the power switch.
2. The power wires were accidentally reversed I.E. positive to ground, neg to 12v. There is a protection diode on the circuit board that did its job and is now shorted. it will keep blowing fuses until its replaced.
Dec 30, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 29 Ltd
  • remove TR18;
Sep 07, 2008 | Cobra 29 LTD CB Radio
Cobra 29 Ltd Classic
In most cases just turning up VR4 is more then enough. Replacing the final, tr14 with another transistor requires changing many more parts to get it to work.
With a new 29, there is no need to change the final. Just turn vr4 all the way up and you will see around 20 - 25 watts. L13 won't gain you a single watt. L12 will raise the dead key, and usually you want a lower dead key for good swing. L14 will gain you a few watts, but don't adjust this unless you have a watt meter. You turn it out to increase wattage, but too much will over bias the final and shorten its life.
You hook it to a watt meter with a dummy load. Then say a steady AHHHH into the mic while keyed. Turn the slug out until the needle stops going up, then back it down to where it stopped.
The easy thing to do, and you will be pleased is just to turn VR4 up. Now, Up is counter clockwise. Its a variable resistor, so the less resistance, the more modulation. So you want to turn the VR down.
that will be more then enough.
Sep 06, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
104 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
