Question about Baby Lock Ellure
Baby lock professional change to big frame error message
I change to the big frame tighten everything down. I center the pattern and I am sure the pattern will fit. But it keeps saying to change to the big frame.
How do i make an x follow the oncreen progress of sewing a single run quilting pattern
Pantograph - IntelliQuilter® ' Computerized Quilting ...
www.intelliquilter.com/iQpedia/Pantograph.php
A pantograph pattern is one that goes from edge to edge, over the entire quilt ...patterns - there are some interesting combinations you can use to create ... Remember to align the on-screen quilt to the quilt on the machine before you sew (use the ...Touch Realign, and follow the on-screen prompts: Find a reference point on ...
Baby Lock: Ellure
babylock.com/sewing/ellure/
With a 5" X 7" embroidery hoop and a wide variety of built-in stitches and designs, ...With 120 frame patterns and a large library of built-in designs (including 40 ... cover so you see your progress and avoid running out of thread mid-stitch. ... Baby Lock IQ Technology is what makes Baby Lock machines so smart and efficient.
[PDF]Quilt Magician Manual updated 4-23-12.indd - TinLizzie18
tinlizzie18.com/images/Quilt-Magician-Manual-updated-4-23-12.pdf
This manual will cover everything you will need to know to RUN your Quilt ... Let's getto know your Quilt Magicianâ„¢... .... pattern boxes at one time, the system will onlyrun the pat- ... You can have as many patterns as you like in each pattern box. Circle for. Start. (X) for ... button and follow the on screen steps to re-calibrate.
[PDF]SideSaddle (SS) Users Manual - The Quilting Solution
Jan 11, 2016 | Sewing Machines
WHY??!! *Check if thread is entangled. Check if needle is bent. So far as I can tell everything is fine, used new bobbin, new needle, still getting error. How do I know if the motor has become locked
Time to take it in and have the repair tech service & clean upper tension assembly. When you clip/ change threads be sure not to pull the thread back out of tension assembly. Snip thread at spool, raise foot to release tension and then pull the short thread out from the needle. The Automatic tension is very delicate and pulling thread out backwards can cause thread/lint build up and problems like your having. Sal the Sewing Gal
Oct 30, 2015 | Baby Lock Ellure
What is the best course of action.I have a 10 needle baby lock Plus, today my "Main Motor Current Error" appeared on display screen. I shut off for short time and started again. Is there anything i can do...
From the Brother web site I find, " If you are receiving a "Main motor current" error message indicates there is a problem with the unit, and it is recommended that you get the machine serviced.
Take your machine to the nearest Authorized Brother Service Center for repair.
You can locate a Brother Authorized Service Center (ASC) in your area by clicking on the link below.
http://www.brother-usa.com/service/default.aspx or contact Brother Customer service by calling 1-877-Brother (1-877-276-8437) Monday through Friday, excluding holidays.
Service Center Locator
Feb 21, 2015 | Baby Lock Sewing Machines
Machine is jumping around on the design
Not really clear on just what your problem is. Are you making an embroidery pattern using a hoop? If so the machine automatically detects the area size the pattern can be embroidered in without striking the edges of the hoop. When a horizon pattern is too big for the stitching area of the hoop the machine switches it to sew vertically.
If this is your case, you can resize the pattern or flip the material to match the direction you want the pattern to sewn.
Also, not all patterns are designed by their creators to stitch out uniformly. Some hop from one point to another then back again making the pleasures of embroidery miserable. Try a pattern you have already successfully done before to test if it is the machine or the pattern.
Then there is factory reset. Check your manual on how to do this and visit the Baby Lock web site where you will find update downloads. Sometimes just powering off the machine and allowing it to set for an hour or so will also allow it to reset itself.
Last but not least and the answer we all hate to hear is, if none of the above are helpful you probable need to have the machine checked by a qualified service person.
Apr 06, 2014 | Baby Lock Esante
Why won't my baby lock ellure plus read my USB stick....I copied a pattern from the internet ...it seems to have read the pattern but when I put it in the sewing machine it comes up P1/P1
You downloaded a toyota dst file. The babylock will embroider the design but it wont display the design or any picture or attributes. It will sew it, but try on scrap fabric first to be sure.
Aug 12, 2013 | Baby Lock Sewing Machines
Baby Lock Jane-thread gets in a big knotted glob by the bobbin, and I have to carefully cut it out as the can't move. it all gets caught inder the material, feed dog and bobbin?
try changing the needle
rethread the machine making sure to use every thread guide
try using a different bobbin--make sure the bobbin is turned the
right way
make sure the thread has not come off the thread take up lever
Dec 05, 2012 | Baby Lock Sewing Machines
How to transfer PES files to my Baby Lock Allure from computer
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
Source: Linda's 15.000 Embroidery Design
Oct 02, 2012 | Baby Lock Ellure
I'm having trouble centering my frame to begin embroidering and am unable to find it in the manual.
See if there is a lever on the front of the plate where the hoop slips in. This should be up to open and once the hoop is in place, down to lock.
Download a free manua here - http://www.babylock.com/embroidery/ellure/
Mar 17, 2010 | Baby Lock Ellure
Baby Lock Embroidery Sewing Machine "ELLURE" Model ESL- Problem: Defective Embroidery Memory Card (part#35205-4) used with the "PTS BOX" and the Palette Ver 1.0 Software Program to transfer embroidery...
Jul 11, 2009 | Baby Lock Ellure
Not picking up the bobbin thread
Make sure the needle is facing the right way. If it's in backwards it won't pick up the bobbin thread.
Jan 04, 2009 | Baby Lock Esante
Sewing Machines Logo
41 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
