Question about Whirlpool AWM5145/2 Front Load Washer
Awm 5145 Hi I have a leak and it seems to be coming from the front left hand side of the machine only between cycle 10 and A. I have check the seal and the hoses and they seem fine? please help me
    President:
  • 1,294 Answers
Possible your hoses into the dispenser box hv a problem; plug off wall. Open the top of the machine to examine the hoses.....
Posted on Jun 25, 2007
Leaking door
Open the door and look inside at the lower left corner where the door gasket ends. See if there is any type of obstruction or foreign object in that corner. It doesn't take much to cause a door leak. Some door latches can be adjusted tighter. Look at the top door latch system and see if has 2 screws in it. You can sometimes loosen the screws and push the latch inward slightly and re-tighten the screws. That will make the door tighter when latched. Not all dishwashers have adjustable latch systems.
Apr 04, 2015 | Dishwashers
I need to seal my juki machine oil leak
hi there
you must know oil leak from where? if it's coming from hand wheel side you just need to replace oil seal who behind the hand wheel - if it's coming from hook side you just need to Decrease the amount of oil from black plastic screw at down place ( near from hook ) at left side.
best regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Mar 18, 2013 | Juki DDL-8700
Whirlpool AWM 1203 Leaks water onto floor about 20 sec into wash cycle. Any solutions ?
It's either a perished door seal/bellow or perished pipe work most likey. Could even be a leak from the dispenser drawer
Mar 24, 2010 | Whirlpool AWM6100 Front Load Washer
Water leaking out slightly from detergent dispenser draw and is starting to rust down left hand front side of machine,checked all water supply and drain hoses but leak appears to be coming from high up...
Your water pressure may be a liitle too high for the machine to handle. Try turning the water valves for the hot and cold water down a bit to reduce the pressure and try it again.
Jun 21, 2008 | Whirlpool Washing Machines
Bosch WFCM 3200 Front load washer leaking from bottom of machine
I would try pulling the machine away from the wall and taking the back panel off. Get yourself a torch and then settle down on the floor while the machine runs a short cycle and wait to find out for certain where the water is coming from and at what stage of the cycle the leak happens.
Safety notes: Turn the power off while removing or refitting the back panel. Keep your hands away from wires and terminals when the power is on, and keep your hands and hair well away from the drive belt while the machine is on!
Once you know where the water is coming from and when, it'll be a lot easier to know what to do about it.
A.
May 27, 2008 | Bosch WFMC 3200 Front Load Washer
Whirlpool awm 5145/4
FILTER MAY BE BLOCKED IRE CLOSE BYE
Nov 27, 2007 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
203 people viewed this question
Sal De
Marvin
Marvin
jimorris77
