Question about Video Game Consoles & Games
Hi, I bought a brand new ps3 console yesterday and everything worked fine when I set it up. I did not have to change any settings in relation to the display at all and it was perfect when I tried out my two new games on it. However, when I went to turn it on and play tonight, the picture size seems to have randomly change itself. It appears to be zoomed in really far and a good portion is cut off the bottom of the screen. I have tried adjusting every possible picture setting on the ps3 and my TV, which is a large Pioneer plasma (not sure exactly what size). Please tell me there is a fix for this and I don't need a new TV :(
  • 4,806 Answers
Hi.
No you shouldn't need a new TV, all you need to do is reset the video settings, follow the guide below >>>>>
  1. Make sure that you have only 1 type of video cable connected between your PS3 and your TV or monitor, an HDMI cable is optimal. If you have multiple video connections the reset sometimes does not work.
  2. Make sure that your TV or monitor is turned on and set to the proper input for your PS3.
  3. With your PS3 in standby mode, turn your console on using the front power button and hold the button down.With the button held down, You will here one beep when the console first turns on, and, after about 4-5 seconds, you will here a second beep. When you here the second beep let go of the button.
  4. If you watch the screen you should see it flicker once or twice and then your system should boot up and go to a screen to confirm your video settings. Simply confirm the settings and you should be able to resume playing your PS3 as normal.
  5. If your system does not boot up and give you the confirmation screen for your video settings, then you should shut the system off and restart the system as normal. This will usually finalize the reset of the video settings.
  6. If your system still is not displaying video then please repeat steps 1-5 again. It is unlikely but, you may have to reset the video 3-4 times before it works with your console. The reason for this is unknown.
  7. The procedure to reset video ,on your PS3, should be complete at this point and you should be back up and running as normal.
NOTES: PS3 "slim" models are always in standby mode when plugged in. PS3 "fat" models must have the rear power switch turned on. If you are only using the composite video cables, then there will be no confirmation screens for your video settings.
Regards.
Posted on Jan 01, 2013
  • 18 Answers
SOURCE: Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Posted on Aug 19, 2007
SOURCE: PS3 not working through HDMI cable
connect PS3 to TV select HDMI channel on TV press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
Posted on Jun 29, 2008
SOURCE: PS3 not working thru HDMI cable
i am having the same problem, so i called the mfg. of the tv and they told me to set the PlayStation to out put 1080i and not 1080p i don't think this is possible. my tv is a Hitachi and they are sending me an update card for the tv, hopefully this will fix the problem. Apparently its a problem with the tv not being able to receive a 1080p signal
Posted on Oct 31, 2009
SOURCE: PS3 - green Bar when playing blue ray on my 50" Phillips Plasma
Green bar or border is due to wrong AV Setting. To resolve this just insert the Blue-Ray DVD and begin to play. Press the Triangle button and select "AV Setting", in AV Setting change Video Output to RGB.
Posted on Jan 14, 2010
  • 4 Answers
SOURCE: ps3 screen margins too wide for tv display
Try holding your power button on your ps3 down till it blinks.(not your main power switch on back of console) I do believe if correct, this should reset your ps3 resolution to an auto set for best display on your tv. It may pop up with a message on resolution, but that should work. I had similar problems and that worked for me.
Posted on Mar 17, 2010
Our Ps3 has stopped communicating to our Sony T.V. The ps3 still works but it won't talk to the t.v. They are both Sony products and the HDMI seems to have stopped working. All other gaming console's
Hi.
You will probably have to make sure the video output settings are set up.
Make sure the PS3 is turned off and make sure that the HDMI lead is properly connected, also make sure you have selected the correct source on the TV.
Press and hold the power button until you hear 2 beeps. That will allow you to set up the desired video output.
If you still have a blank screen then I would change the HDMI cable as that could be faulty.
Good luck!!
Regards.
Dec 08, 2011 | Sony Playstation 3 (PS3) Console
We have a ps3 with HDMI cable, hooked up to a mitsubishi HC1500 projector. Everything was working fine yesterday but today there is no sound on the ps3. We get sound with tv and hddvd. I have put it on...
There may be any speaker problem.............
The possibilities are
1> to change the speaker by psp repair shop
2> or any loose connection
3>any can change in your psp settings
you can take your psp to repair shop or else download the repair guide which will help you to get rid of many problem
Click Here to download repair guide
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
Everything is connected, i can hear it, but cant see it
The previous answer is partly right. Are you both using HDMI, or are you changing connection method. If you change method, you must reset the graphics settings, which can be a bit tricky without a screen. Turn off your PS3, then Press AND HOLD on the Power Symbol for some time, or until you hear the beeps, and the flight flashes green, then, it should work.
Sep 24, 2009 | Sony Playstation 3 (PS3) Console
I have the same problem with my Samsung LE46A656 A1F Full HD
If it was doing it on your old console then its the TV not the PS3.
Causes: HDMI cable (Replace cable), HDMI socket on TV (Get it repaired), If it happens on all HDMI inputs then the video board maybe faulty, Interference - location of PS3 to other equipment.
The first thing to do is move everything else away from your TV except for the PS3, now factory reset the Samsung TV and make sure your firmware is up to date my records show that an update came out in May for your TV, also factory reset the PS3 and setup the HDMI video settings using the wizrad in the PS3, now connect the PS3 through all HDMI inputs to see if its one input or all, if all inputs are the same then the TV maybe faulty.
Let me know how you get on.
Thanks
Sep 05, 2009 | Sony Playstation 3 (PS3) Console
Star Wars the force unleashed will not start up on our PS3.
Check the regional settings in the PS3 as the game may not be set to the same settings if it comes from us japan ect, you should be able to reset them to read the disc
May 12, 2009 | Sony Playstation 3 (PS3) Console
Weird
I believe only voices from other players come through on the headset. Other game sounds (cutscenes, gun shots, explosions, etc.) come through the TV. Try checking the Chat or Accessory settings on your PS3 to see if there's an option to change where the sound comes from. It'll be in the PS3 dashboard (press the PS3 button on your controller). I hope this helps and don't forget to rate. Good luck and thank you!
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
I have had my ps3 for four months and it works fine. I just bought the new call of duty five yesterday and it played awesome. I went to turn the ps3 on right now and I click through the multiplayer, online...
a lot of problems with the new COD5...update firmware to2.52...cod5 is very cpu intensive..you may have overheated your CELL cpu...let it cool and try again
Nov 12, 2008 | Sony Playstation 3 (PS3) Console
Ps2
hold down the power button untill it beeps twice. about 3 seconds which should restart the settings to the default composite settings. from there you can change the settings back to hdmi or whatever you had them at before.
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
