Question about Baby Lock Esante
How to thread bobbin, insert in machine correctly. Lost manual.
Machine: is a babylock sewing with nancy
    Scholar:
  • 67 Answers
Go to link: http://www.youtube.com/watch?v=YL433PhG05c
a vidio is here that will show you the route to follow for your automatic threading to work. You may need to watch it a few times as it is demonstrated very quickly near the begining only once.
Posted on Jan 18, 2009
How do u thread a babylock sewing machine .....bobbin not working threads get tangled
Search the internet for a manual for your machine.
Make + Model + the word "Manual" or "threading instructions"
Sep 30, 2016 | Sewing Machines
Tip
Sewing answers
manuals can be found at,
ManualsLib Makes it easy to find manuals online
singer manuals and support,
Customer Support
tips and hints,
Sewing Resources
how to videos,
SingerSewingCompany
presser feet tutorials,
SingerSewingCompany
singer replacement parts,
Replacement Part Availability
parts for ANY machine,
http://www.sewingpartsonline.com/
household machines,
Sewing Machines
industrial machines,
Industrial Sewing Machines
babylock,
http://www.babylock.com/support/faq
singer manuals.
Instruction Manuals
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
on May 24, 2015 | Sewing Machines
How would to insert the bobbin in the sewing machine brother VX 1400?
There is not much of a secret to inserting a bobbin in a sewing machine. A couple of things to check, the thread from the bobbin should be pulled through the slot of the carrier, and make sure the thread comes through the sewing hole by manually lowering the threaded needle and then lifting it out of the hole again after it has picked up the thread from the bobbin. The video link posted below is useful if you have a Brother sewing machine.
If the stitching is still not right then check that the needle is fully inserted in its housing. (Push the needle up as far as it will go then tighten the screw.)
How to wind and install the bobbin and thread the sewing machine PART 2...
Aug 24, 2014 | Sewing Machines
Why is my thread nesting on my Babylock BMP8?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Jan 14, 2013 | Sewing Machines
My sewing machine stopped sewing. I changed the needle cleaned out the bobbin area. It looks like the top thread is not picking up the bottome thread (changed bobbins too). the pressure feet are working...
Hi, Nancy! You obviously know how to look after your machine, but sometimes we get so excited about a new project we forget some of the basics...I know I do! Is the bobbin in the bobbin case correctly? There may be a diagram on the machine showing you the correct placement. When you replaced the needle, did you make sure the groove in the needle was facing the front of the machine? That groove is actually another thread guide and it's important that it be inserted correctly. You might check for lint between the upper tension discs. I hope one of these suggestions helps!
Nov 15, 2010 | SINGER 7470 Sewing Machine
On a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
Jul 05, 2009 | Baby Lock Ellure
Tension settings for the babylock sewing machine
I found that the tension setting of 1 worked. The main problem was the machine had thread wound around behind the bobbin. I had to take the plates that are under the foot out, clean out the thread, oil the machine and use a spool of thread that had more weight than the little spool I was trying to use.
May 15, 2009 | Baby Lock BL1556
Embroidery bobbin problems.
Each manufacturer have their own bobbins.......not interchangable
Apr 28, 2009 | Baby Lock Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Sewing Machines Logo
108 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
