Question about JVC DLA-RS1X D-ILA Projector
Lamp warning light is on
I am trying to turn on my projector and after standby the lamp warning light is coming on not allowing me to turn it on or off unless I pull the mains
3 Suggested Answers
SOURCE: Lamp replaced, sequence from Manual (p.49) for 2010+ hrs fails
Apparently, the above posted steps do work, but they are finicky. The manual suggests that you do the aforementioned steps with the remote - I had tried with the remote and when that did not work I tried directly on the controls on the unit itself. Neither had worked - after multiple attempts, hence the posting above. The solution was that the various steps need to be done speedily - when I previously did it I apparently did not press the sequence rapidly enough. Nothing in the manual suggests that this is the case (and in fact I thought I had previously followed the steps in rapid succession on at least one of the many times I had tried, but apparently not quickly enough). I never could get this rapid succession of steps to work with the remote (as the manual said I needed to), but I did ultimately get the rapid succession of steps to work when done directly to the unit itself. The first three steps need to be completed within approximately 1-1.5 seconds, the final push of the volume+ button did require 2 or more seconds before the process was recognized (and complete). Never did have a single FixYa party try to address my issue - perhaps you only really get responses from them when you pay for their monthly service.
Posted on Sep 26, 2009
aviral_srms
  • 1216 Answers
SOURCE: After JVC G15 runs for
the bulb of your projector have a lamp life of 1000 hours and this is probably the decline period of your bulb, that is it's life is near it's end.
Emergency light signifies this only and this is the cause of your problem.
please replace your bulb.
thanks
Posted on Dec 12, 2010
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
Will not coming on ,standby light is orange temp and lamp light not on
hi,
Just try to reset the lamp hour of your projector. For resetting the projector do the following.
While simultaneously holding down MENU/HELP, ENTER and Down arrow button on the projector, Press STANDBY/ON on the projector.
Remember one thing lamp hour reset is recommended only after the lamp replaced. Before going to buy a new lamp just reset the lamp hour and confirm that the projector doesn't have any other problem.
If these doesn't help then check the lamp of you projector chances for lamp became faulty.
ok
Mar 19, 2011 | Sharp XR-10SL DLP Projector
How do you install new light bulb
The Projector will detect the lamp life itself. It will show you a warning message renstrike_1.jpg
When you see this message, change the lamp as soon as possible. Make sure the projector has been cooled down for at least 30 minutes before changing the lamp
  1. Switch off the power to the projector by pressing the Power/Standby button.
  2. Allow the projector to cool down at least 30 minutes.
  3. Disconnect the power cord.
  4. Use the screwdriver to remove the screw from the cover. (1)
  5. Push up and remove the cover. (2)
  6. Remove the 2 screws from the lamp module. (3)
  7. Pull out the lamp module. (4)
To Replace the lamp module, reverse the previous steps,
Feb 28, 2011 | Optoma EP716 Multimedia Projector
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
PT-L785U Projector
if the lamp warning light is flashing, this indicates a defective ballast (lamp power module). if the lamp warning light is lit steadily, then the lamp would be at fault.
Oct 13, 2008 | Panasonic PT-L785U Multimedia Projector
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
MULTIMEDIA PROJECTOR
have you ever seen the lamp come on? has the unit been used for a prolonged period with lamp on?
May 24, 2007 | Sanyo PLC XU35 Multimedia Projector
When u switch it on a timer comes on for 30 seconds then the projector turns off can any one help please
Had the exact same problem, after my projector was powered off upruptly.
Turnedout all I had to do was push down slightly on the tempreturesensor/fuse (is opens the power circut if the projector gets too hot,and thus doesnt allow any current)
Here is the full repair/service schematic for the projector. It should help you locate the sensor.
Good luck
http://yama.co.za/forum/index.php?topic=146.0
Apr 13, 2007 | Sanyo PLC XU30 Multimedia Projector
JVC DLA-RS1X D-ILA Projector Logo
Top JVC Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Electro Med Services...
Are you a JVC Office Equipment and Supply Expert? Answer questions, earn points and help others
