Some times my pc hang and showing initializing and establishing a link
  • 7,627 Answers
You didn't supply the Computer make, model or the OS you are using. It would be very helpful to have that info. My first suggestion would be to runn a Malware scam and a Anti Virus scan. A general clean of the software environment. 1. download Freeware MALWAREBYTES at :http://www.filehippo.com/download_malwarebytes_anti_malware/. In the install UNCHECK the PRO TRIAL version, you want the freeware version. Run a FULL SCAN, DELETE ALL RESULTS, REBOOT. 2. Download CCLEANER Freeware at : http://www.filehippo.com/download_ccleaner/. This will clean the junk from your machine, and in TOOLS, STARTUP, disable ALL unnessary startup programs to speed up your computer. You can find many Freeware programs on FILEHIPPO, MAJORGEEKS . That's a start. respond to post for further assistance.
Posted on Jan 02, 2013
During initial setup, my SlingCatcher hangs when trying to update the firmware.
Welcome to club! No solution as yet and it was escalated to a senior engineer who also seems to have no idea what is going on. From all appearances, it would seem the SlingCatcher is unable to establish contact with the servers at Sling. Unfortunately I do not have a sniffer available at this time to see exactly where the SlingCatcher is try to go. The box gets an IP address and can be ping'ed so the core software is working. Hopefully more answers will be forthcoming.
Mar 11, 2013 | Audio Players & Recorders
AT POST motherboard hang at INITIALIZING USB.....
Several things you can try:
  • Remove the CMOS battery leave for 10 minutes and re-insert and try to reboot
  • If this fails to solve the issue, check the BIOS (F2 on boot) and disable USB legacy support
  • Then if that fails, try swapping out the RAM modules until you manage to get a successful boot.
  • If you suceed in this, download memtest and check the integrity of the ram modules, it may be you have an intermittently faulty ram module.
  • If this fails, it is likely that the USB controllers on the motherboard are damaged
May 19, 2012 | ASUS P5GL-MX Motherboard
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
Only displays initial power on screen (SANSA m240 1.0GB)
try changing the battery...it works sometimes....
Aug 11, 2009 | SanDisk Sansa m240 MP3 Player
OK I had the RCA DMC425 plugged into my laptopalright easy.I unpluggled eveything turned off the laptop so i can clean around my computer desk.When i finished i plugged everything back in and soonenough it...
troubleshooting a network is a multiple step process.
1. Establish that your modem is working properly, and plugged in. As per the diagram shown here:
  • Your "Cable link" light should be on (signifying that the outside cable is properly connected to the router)
  • Your "Internet" light should be on (signifying you have an established Internet connection)
  • And, most importantly, your "PC Link" light should be on (showing that at least as far as the modem is concerned, it is detecting that the computer is plugged in to it.
2. double check to make sure that the network cables are seated properly, and plugged in all the way. the PC link light should give you an indication for modem-side- the LED light around the network cable jack on the laptop should give you an indication PC-side.
3. check on your laptop for any security software that may restrict new networks from being detected and disable them to test. For example, Symantec or Mcaffee Firewall can sometimes block a "new" network from being detected.
4. Completely shut down the laptop and unplug the power cord from the modem. Plug the modem back in. Wait around 3 minutes for the modem to initialize and do it's thing- then turn on your laptop and see if this resolved your issue.
If this doesn't work, you may want to try other things, such as resetting your network, and removing/re-installing your network adapter drivers.
Aug 03, 2009 | Acer Computers & Internet
keep the hold switch to right side and connect to pc...then format the player or try updating the firmware..tht must do...
Jun 17, 2009 | SanDisk Sansa m240 MP3 Player
Reboots at different times, some times windows logo is grayed out and hangs
its is possible that you have some bad memory search & download a program called memcheck 1.70 or later, and either put it on a formated floppy or burn onto a cd ,make sure that the boot sequence in the bios is set to go to that drive first
the pc will boot into this program and will keep running untill you stop it,if their are any errors it will show up ,you will need to establish what memory chip it is, if you have more than one chip.
it could also be a power supply, supplying iregular voltage.
also xp requires at LEAST 256 mbs to run badly, more is better.so if you are using less than 256 mbs it will be the problem.
good luch
Terry
Mar 10, 2008 | ASUS P5P800-MX Motherboard
Computers & Internet Logo
David Payne
David Payne
