Question about GE (PSS26MSRSS) Side by Side Refrigerator
Amana SXD27Q2E side by side fridge....icemaker stopped making ice a couple of days ago. Seems that there is ice in the tray, but maybe it is not freezing hard enough for the ejector blades to push it out? It was making noise the other day and I opened it to see the blades stcking straight up w/ half ice cubes frozen to them. ?????????????????????????
    Sergeant:
  • 229 Answers
There is ice blocking the assy. You need to get in there and clean it out. You WILL find a piece of ice that is blocking the assembly from turning. Happens more often than you think. Be careful when you get the piece out the blades will revolve forcefully once unhindered.
Posted on Jan 18, 2009
The freezer has stopped cooling...meaning the fridge has stopped too. The fan continues to run, but blows warm air. Twice before the fan had frozen and stopped blowing the cold up to the fridge...we had...
replace the p.t.c. overload on the compressor body of the units compressor in the rear lower end of the unit,its not letting the compressor start and then not cooling
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in...
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Sep 25, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana icemaker not making ice
Just had the same problem,when I pulled the fridge away from the wall I noticed the copper tubing running from the water source had a kink in it. Got a new line and problem solved it also mentions this in your manual under trouble shooting.
Jan 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool fridge icemaker stuck upside down (side by side fridge)
it seems the ice maker cam asm is broke it will have to be replaced
Dec 20, 2008 | Refrigerators
We have a whoolpool stainless steel side by side fridge. We noticed a couple of days ago that the ice maker isn't making ice. What should we look at to see what isn't working that should be working?
hi there,
you need to detemine if the problem is ice production or just the dispenser.
if you have ice in the bin, then the icemaker is making ice but the dispenser is not working. you could have an ice cube jammed in the mechanism. also check the ice lever for any breaks.
if you have no ice in the ice bin, then the icemaker is not working at all, in which case, i would recommend replacing it.
Nov 06, 2008 | Whirlpool Refrigerators
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Amana Model ARS2667BW
sounds like the compressor or compressor relay. i would call a technician for this one.
Sep 13, 2008 | Amana 22.6 cu. ft. Side-By-Side...
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
100 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
