Samsung LCD TV having a dim display. Have tried all the settings but does not work.
The display is very dim. I have tried all the settings but non worked. Also open the back cover to find any visible faults, but seems to be okay. All the capacitor on power/inverter board seems to be okay. Where else the problem can be?
  • 933 Answers
Is the entire display dim or just a portion of it?
Posted on Jan 01, 2013
  • The whole display is dim. I can also see some flickering going on, on low backlight and brightness settings, however on higher values flickering is not observable.
4 Suggested Answers
westytech
  • 120 Answers
SOURCE: Westinghouse lvm-47w1 picture goes dim
Hello, I can tell you from experience that this is an inverter issue. Both the master and the slave have several transformers and sometimes you can't tell if they are damaged or not. I would recommend testing the leads from the inverters to make sure which one of the two is the one causing the dim picture.
Posted on Apr 15, 2010
  • 304 Answers
SOURCE: I have a Samsung LNS3251D 32-Inch LCD HDTV , that
In almost all cases where the set is taking a long time to turn on and then turning off it will be the Power Supply board that will have bulging capacitors, usually three to five. Look on the upper right side of the Power Supply and look for any blown caps. You can replace these caps and you will be fine. Now the other cause can be the Power Switch is shorting out. You can disconnect the the Power Switch but not the IR sensor and then turn ON the set with your TV remote and see if this stops the problem. If you are not skilled in component level repair on the Power Supply board then buy a new Power Supply board and install it.
Posted on Apr 16, 2010
SOURCE: I have a LCD samsung
It is not impossible but it is unlikely that the inverter will fail RIGHT AFTER you replaced the caps.
Are you sure you put their polarity properly?
Try disconnecting the inverter and powering the TV on again. it should be turning on and staying on, even without the backlight.
if it doesn't it is the power supply you're looking at.
Posted on Oct 29, 2010
Why does my TCL tv stay dimmed and very dark screen? I've reset it and everything?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 30, 2017 | Televison & Video
LCD screen is white, dim picture and sound works fine
seems the white balance is set inccorectly and the brightness is set wrong check your TV's menu and set them back to normal or reset the display controls in the tv menu if it turns all back white and dim then the display panel of your tv is needing repair
Mar 02, 2017 | Televison & Video
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
SAMSUNG 52 IN.LCD TV, WILL NOT COME ON, THE POWER & LIGHT BUTTON CLICKS ON & OFF CONSTANTLY
Sounds like it may have taken a surge. Did you unplug the set? Try that and give it 5 minute time out before powering back up.
Did anything happen before the problem started like a power outage? big storm? Brown out condition (that's when power is low due to excessive AC use in the summer and the lights grow dim etc - very bad for electronics and motors too)
Do a little more detective work and post your suspicions and findings.
Worse case scenario is there is something wrong inside your set and may need a visit to the repair center. How old is it?
Hope this helps.
Aug 26, 2012 | Samsung Televison & Video
Sound no picture
I think you hit the wrong button before....
To restore the settings please try to restore factory setting and see what happen..
Nov 22, 2011 | Samsung LN22A450 22 in. LCD HDTV
I have a 42 that has begin to strobe. it is like the back light problem but instead of just losing picture all the way it just strobes on and off real fast. when you first put on game where backlight is...
First, try setting all display settings to default or 'normal' or 'standard' and disable any picture processing functions. If your TV is LED backlit then the LED dimming function may not be working correctly (dimming is done by rapidly switching the LEDs on & off).
Feb 11, 2011 | Vizio 42 in. LCD TV
Hello i have a samsung pn50a400c2dxza it non stop clicks and the screen comes on dim and goes back off and back on .when i unplug it and plug it back in it does it right away.
Wow, old post but some need not comment unless they know what they are talking about, this is a PLASMA TV, no lcd panel, tcon or ribbons, please abstain unless you know. Thank you !
Aug 30, 2010 | Samsung LN40B530 40 in. LCD HDTV
Delphi XpressRC XM Radio backlight problem
Same thing happened to mine until it permanently went dark - no brightness. Problem is with the LCD display that is defective. As this model does not have a separate filament bulb unlike the non color model, it cannot be repaired. Likely too expensive to replace the color LCD display if avalaible. Next one I buy will be a non color version which has separate bulb.
Sep 17, 2009 | Delphi XpressRC XM Satellite Radio...
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
