Question about Ricoh Aficio Mp 4000 Copier/Printer/Scanner
My mp4000e ricoh copier displays an error codes of sc 324
Please give me the solution for the error code sc 324
Como quitar error sc324
Posted on Nov 19, 2013
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Sc 558 error code on Ricoh Pro C720
That is an oil supply pump error for the fuser. It probably needs to be replaced.
Jan 29, 2015 | Ricoh Office Equipment & Supplies
Ricoh aficio SP4100NL error sc 546
Ricoh uses error codes in order to alert users that there is a problem with the functioning of the copier. Codes that begin with "SC" refer to issues with the fuser components, which heat up to bind the toner or ink to the paper. While clearing the code can be accomplished by most users, it is important to point out that clearing the code does not fix the problem. Codes that reappear should be addressed by a certified Ricoh technician.
Instructions
    • 1 Press the "Clear Modes" button. This button will be on the main panel.
    • 2 Press the "1,0,7" keys in succession. You do not have to hold the buttons down together but need to press and release them in this exact order
    • 3 Press and hold the "Stop" key. You will need to hold this button down until the Ricoh enters service mode. The touch screen display will say "service mode" and three soft keys will appear.
    • 4 Press the "Exit" button. This button will be on the touch screen display in the upper right hand corner. Once pressed, the copier will return to normal operation mode.
    • 5 Turn off the main power. The main power button will be located on the side or front of the copier.
    • 6 Turn the power back on. Once the copier is powered back up, the service code will be cleared.
Jul 20, 2014 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
Richo error code sc 829
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
Apr 05, 2012 | Ricoh Aficio 1035 Copier
Ricoh 1515 is locked up with error message SC:820 code 612. How do I fix the problem
820 Self-diagnostic error: CPU
Symptom:
• An unexpected exception or
interruption occurs during the self-
diagnostic test.
• An error is detected in the MBU.
Possible Cause:
• Defective controller
• Defective firmware
• Loose MBU jumper
Code 820
MBU error (The jumper is loose.)
Set the jumper (on the MBU) correctly.
The following codes are displayed:
• SC: 820
• code: 612
• detail: 40000000
Feb 03, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio Mp 4000 Copier/Printer/Scanner Logo
964 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
