Sony FWD-50PX2 50 in. Plasma Television
Problem for Sony FWD-50PX2 50 in. Plasma Television
Loud bang, unit stopped working
By ebailey100 on Jun 24, 2007
While playing Xbox, our Sony plasma suddenly let out a loud "bang" and went to black. Efforts to shut everything off have resulted in the green indicator light coming on for a short period of time, several "clicking" type noises and then a steady (not blinking) red indicator light and no action on the unit's screen -- totally black.
Any suggestions/ideas for what could have blown out or otherwise happened?
Thank you.
Same Problem
Feb 09, 2008
-   when you plugged the unit you will hear 8 clicking noise and stops after that and picture is blank. i notice that the fan inside is not working either.-   Guest
Feb 02, 2008
-   Hello hey there were no loose caps that I could find. Does anyone have any other solutions????? thanks Steve-   ssisbest
Jan 31, 2008
-   Hello my FWD-50PX2 just did the same thing????????????/-   Guest
Best Solution
posted on Apr 24, 2008
Very Helpful)
mhlady
Rank: Apprentice
Rating: 90%, 5 votes
My Sony FWD-42pv1 had a similar failure, but no loud bang, just a click off. When trying to turn it on after that, the green LED would come on for a few seconds, then blink off, then repeat a few times, before finally just giving up and going to solid red.
The problem turned out to be a failed Y-SUS board. The fuse on that board was blown, and the board had also failed (replacing the fuse wasn't enough). With a new board, the TV is running fine.
Was this helpful?
Yes
No
Solution #2
posted on Jun 28, 2007
Helpful)
MikeNJ1964
Rank: Guru  Sony Expert
Rating: 89%, 737 votes
I have seen the caps in the power supply vent, which means they get hot and the top pops up and splits open, resulting in the "bang" sound. If you have experience in electronics then remove the back of the set and examine the power supply, looking for any caps whose tops are bowed upward, and replace.
Was this helpful?
Yes
No
Popular Solutions for Sony FWD-50PX2 50 in. Plasma
Questions and Unsolved Problems for Sony FWD-50PX2 50 in. Plasma
Do you recommend Sony FWD-50PX2 50 in. Plasma Television?
Answer
Answer
we have just bought a Teco LCD TV TA42N1PR. We have plugged in the aerial and there is no sound.... (More)
Answer
tv has sound but no picture, screen is black
Answer
i do not have cable television. how do i find the antenna? is thee an antenna?.do i find an antenna... (More)
Answer
getting error on VGA input "Port set to Fix"
Answer
No display, when unit is turned on. Imediately goes to standby mode.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
