RECORD PLAYER PLATE WILL NOT SPIN
I have a GE Transistor 600 record player that sometimes plays, I am trying to figure out how to remove the record changer from the unit. Itt seems there are two screws holding the unut to the case that tighten when I turn them in the counterclockwise direction. I can see between the record changer and case that the fastner is secured to these screws but will not release. Do you know how to solve this problem or where I can locate a service manual for this?
Thanks AW
  • aw4000 Jan 18, 2009
    The two balance screws have a metal fastned attached to the bottom of them. The balance screws protrudes the fastner which have an 1/4 " elongated opening, tapered in shape and the the metal is folded at a right angle, Do I need to push and force the fastner from the Screw in order to remove them?
    Thanks,
    AW
    Sergeant:
  • 229 Answers
Blast from the past. Those screws are balance screws. You have to work on it from the bottom. There is a belt that spins the assembly you will have to replace probably. Be careful though cause when you work on these they tend to drop out unexpectedly etc. Hope this helps.
Posted on Jan 18, 2009
Low volume recording on reel to reel tape deck
Problem could be in either the record or playback circuits of unit. Try playing back a tape in another machine to see what the volume is like. If also low then the issue is with the record amp circuits.
Fixing will not be cost effective, however.
Aug 21, 2017 | Audio Players & Recorders
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
I have a few purchased DVDs that will not play. Two have played one time. The message is "No Disk". Thanks. Suzanne
Try getting a lens cleaner and running it. I dont know why but sometimes when the lens is dirty they will get picky about what they will play. You would think that they would just quit! Anyway the lens cleaner should work. Also avoid touching the hold in the middle of the disc. That is where the drive hub that spins the disc goes. No spin no play. Try cleaning the holes on the discs that do not play. Good Luck!!
Jul 06, 2009 | JVC DR-MV77SU/78BU DVD Recorder/VCR
Turntable won't turn
There is usually a cotter pin at the center of the platter around the spindle base. This can be removed with a screw driver using a twisting motion. There is a blades worth of space between the clip and the spindle base. Screw driver should be in vertical position. Sometimes the vinyl slip mat must be removed first. Watch that clip, cause it can go flyin. Once the clip is removed, the turntable should let go easily.
May 03, 2009 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Spinner problem!
manufacturers issue. Get in touch with them they will arrange a replacement .
Dec 25, 2008 | Insignia NS-PDVD8 Portable DVD Player
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
TOSHIBA dvd PLAYER/RECORDER sd-V394
You could try clening the laser lens with a damp Q-Tip, also gently turn the spin motor spindle by hand... it should be free. If it's binding or tight then it's bad.
Geno
Mar 05, 2008 | Toshiba D-R2 DVD Recorder
DVD FROM EUROPE
Because it's been recorded using Pal or Secam...Try this site to make your recorder "Multi-region";
http://www.dvdexploder.com/how.htm
Dec 31, 2007 | Panasonic DMR-ES10 DVD Recorder
748 people viewed this question
 Grubhead
Grubhead
