Question about Whirlpool Dishwashers
Whirlpool ADP5406 dishwasher stopped working
I have a Whirlpool ADP5406 and it suddenly stopped working mid cycle. The start light is intermittantly flashing, but no sound from the motor. Can you help?
  • 3 more comments
  • Anonymous Mar 25, 2014
    Start Light Flashing at the end of a cycle
    Start light flashing
  • Anonymous Mar 31, 2014
    hey there i have this, i dont no if it is a cold fill or hot fill, can u help ?
    hey is this a hot fill or cold fill ?
I had this problem with the ADP5406 too, but managed to solve it. Here's what I did. First I turned the dishwasher off at the mains. The dishwasher was full of dirty water so the first thing was to drain this. I managed to lift the dishwasher up onto a couple of buckets to let gravity do the work of draining the water out of the drain hose and into a bucket. I then unclipped the plastic lower front of the dishwasher. To do this tilt the dishwasher back a bit and release the fairly obvious clips underneath the wide plastic part at the base of the front of the dishwasher. Once this is off you will need to undo 4 torx screws to remove the lower metal access panel. Once this is removed you will be able to see the drain pump. Be very careful at this point since all the metal in the dishwasher is unfinished and extremely sharp. It's like working with 30inch long Stanley knife blades all around your hands! The drain pump is at the front, just left of centre and attaches directly to the sump. To detatch it, first unplug the plug that supplies it with power. Once this is unclipped, press the tab in on the edge of the pump so that you can turn it anticlockwise to undo it. It should come out in your hand now enabling you to pull the impeller out of it and give it a good clean. My pump was full of mush and grime and seemed to be stopping it from working properly. Refitting everything is a straightforward reversal of removal. Good luck.
Posted on Jun 05, 2009
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
Why did my quiet partner II whirlpool dishwash just stop mid cycle?
see this possible causes:
Water-heating cycle
heat, wash, and rinse has the 3 cicle, principal problem is the heat cycle, when the water reach the level ( by heating water elements) test the heating elements , most ot the time fixing this .the problem is o.k
sincerely. God bless you
May 04, 2012 | Whirlpool Dishwashers
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Sep 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Washer keeps stopping mid cycle
Bad timer motor or mechanism...accordianman
Mar 21, 2008 | Dishwashers
Whirlpool Dishwasher Fills and then Stops
  Check your connection where you connected dishwasher to power cord.
Oct 25, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwashers Logo
667 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
