Question about Samsung Np-q430 Series Motherboard W/ Intel Cpu I5-450m Ba41-01280a Ba92-06772b
Motherboard fan may not be working, case feels hot
    New Friend:
Goto Piriform web site download program called Speccy doesnt take long at all and will show you the details of your system and the themperature ? Lots of other good software there as well including CCcleaner all FREE !
Posted on Jan 01, 2013
Hi, I have a newly installed desktop with Biostar A770E3 motherboard, AMD Phenom II X 4 945 3.0 GHz CPU, XFX GeForce 8600GT video card and Logisys case with 480W power supply. And Corsair 4GB X2 DDR3 RAM....
if you have a different video card try that, seems like the fan should spin on the video card. or pull the video card then reinstall see if that makes a difference beeps or something
Apr 20, 2017 | Biostar A770E3 AM3 AMD 770 ATX AMD...
Fix stuttering and pulsing fans
Clean them or replace them.
Mar 09, 2011 | Computers & Internet
Hi, have an Acer Aspire One netbook which is 11 months old. I find it gets really hot on the left hand side away from where the power cable is. Is it normal, I am told netbooks dont have fans, so how do...
Yes it is normal. Many computers run very hot these days. It is because of packing lots of heat-generating components into small packages. Fanless computers cool down via the use of heatsinks which transfer heat into the air passively. Just like an electric stove eye left on high will heat up a room without a fan. Your computer's external case is probably actually part of the heatsink. The place where you are feeling the heat is most likely where your power regulation components are located on the computer motherboard, thus the extra heat in that place. It could also be an internal copper heatsink that is pulling heat away from multiple internal components and is connected to the computer casing in the spot where you are feeling the heat.
Nov 30, 2010 | Acer Aspire One AOD150-1920 Netbook
Why my computer automatically shut down eventhough it working 10 to 15 mins?every time i restart it will shut down again...what is the cause? do i need to replace the new one(motherboard)?
You could have a problem with your OS, it could be viruses, or other things.
It could also be a force shut down by your motherboard. Before you replace the motherboard, check to see if you computer might be over heating. Touch the heatsink on your CPU/Motherboard. Feel if it is too Hot or Cold. You only want it to be warm.
Mar 08, 2010 | EliteGroup P4VMM2 Motherboard
Hp a705w desktop (pc on fan on but no signal to other locations)
Motherboard is broke downs. not responding even beeps. mostly we dont see anything suspecious when we look at the mainboard. we are talking about micrro technology.
take the service to get assist.
have a good evening.
May 28, 2009 | HP Compaq Motherboard
Fan not working
What can cause the fan not to work, is the voltage not getting to it from the motherboard meaning there are bad components on the motherboard that isn't allowing it to get there such as bad IC's and because of this the laptop will get very warm or hot to the touch and you can mainly feel it from the keyboard and moreso from the mousepad and its buttons.
I've seen this problem before and replacing the motherboard is the best option in this case unless you want to take it to a electronics shop and they may be able to troubleshoot the problem component level and see where the problem is but they will probably tell you to replace it as well since they are complicated to troubleshoot.
May 28, 2009 | Acer Computers & Internet
COMPUTER SHUT DOWN THEN RESTAERT BY ITSELF. Asrock GFSB800 motherboard
check your fans inside on motherboard are working. any component that gets hot on the motherB will reset the computer so it will not burn your processor. if thats not the problem, check videocard. adding another fan to take heat out of computer case also good idea.
Apr 14, 2009 | Computers & Internet
Pc tower gets very hot, and is starting to frezze during work ,
If this unit is enough to feel it, then your fan(s) are not working. The power supply may need to be replaced but along with it the CPU fan and case exit fan(s).
Mar 28, 2009 | Computers & Internet
Ga-m61sme-s2l motherboard always shut down within 5mins
It sounds as if the motherboard is having a temperature safety shutdown. This occurs when the temperature of the CPU exceeds a certain limit.
First off: Please check your CPU fan, power supply fan, and graphics card fan(if you have a gfx card) that they are working. If not, I would highly recommend replacing the fans or at least cleaning them and attempting to get them started by rotating them manually.
Please enter your BIOS (See Here for instructions) and navigate to "PC Health Status" - check the entry for the CPU temperature. While in the BIOS there is little strain on the system, but if the temperature is above 40 degrees Celsius in this state it may be prudent to check the fan setting. Also, check if there is a CPU Fan fail warning/CPU warning temperature - on average the limit should not exceed 60-65 degrees Celsius, max. Set any Fan speed or mode settings to maximum if able.
Try again.
If problem persists, and you are sure the temperature is not too high and/or the CPU fan is working, it may be the power supply itself. It is possible for the power supply to shut itself off in extreme cases such as when a power supply's fan stops working, and the temperature of the power supply rises to an unsafe level. Sometimes the fan will work initially but quit after a certain time. The fan requires replacement if this is the case.
Let the computer sit for a while and check to make sure it is at or near room temperature. Attempt to restart the installation process. When the power is cut, feel where the power supply meets the case to check whether or not it is particularly hot.
Replacement of the power supply's fan should solve that problem. I recommend taking it to a repair shop.
If that is not the problem, a last resort is that the harddrive is overheating and causing a system crash. With the case open, start the computer (mindful to be careful and always touch a large metal object such as the computer case itself before getting your hands near any components to prevent static damage), and wait for it to crash. Place your hand gently on the harddrive. If it is very warm or hot to the touch, most likely the harddrive's actuator arm, circitry, or data plate is malfunctioning and the drive should either be taken to be repaired or replaced.
If none of the components in your computer are particularly hot, please come back with more information on your computer, such as the parts, what you are cd you are booting, any new hardware, etc.
Dec 16, 2008 | Intel Motherboard
Intel d845hv board problems
This is not a problem with the wires. This is a failure of the motherboard and/or powersupply.
Try the following:
  1. Take any components that are not necessary to boot the computer1.gif. Try turning it on again
  2. Try taking all parts (motherboard, power supply) out of the case and then put them back in (I know that sounds weird, but it has worked twice for me before).
  3. If you get to this step, either the motherboard of power supply is shot. The easiest to try would be a power supply. Replace it if you have one laying around or borrow one out of another machine for troubleshooting purposes. This is assuming they are standard ATX power supplies.
  4. Place your finger on the heatsink for the chipset1.gif. Feel around for any extremely hot chips. If you find this, your Bios is shot. If you cannot locate the bios chip, just feel all the chips. The Bios chip should be mildly warm but never HOT!
Feb 29, 2008 | Computers & Internet
Samsung Np-q430 Series Motherboard W/ Intel Cpu I5-450m Ba41-01280a Ba92-06772b Logo
43 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
