Question about Intel Motherboard
Enable hypthreading i3 2120
Hyperthreading supported but disabled ?
  • Intel Master
  • 5,660 Answers
The Intel Core i3, model 2120 Microprocessor is based on the Nehalem micro-architecture,
http://en.wikipedia.org/wiki/Nehalem_%28microarchitecture%29
In the old days you had Intel Pentium 4's, that had Hyperthreading Technology. HT.
One REAL processor core operating, and one VIRTUAL processor core.
The Processor teamed up on the task at hand, using TWO processor cores.
Yes, you guessed it. TWO processors.
One REAL, one VIRTUAL.
The Nehalem micro-architecture brought HT back out.
Then the Sandy Bridge micro-architecture came out. Came out to replace the Nehalem micro-architecture,
http://en.wikipedia.org/wiki/Sandy_Bridge
The Intel Core i3 2120 is based on the 32nm Sandy Bridge, micro-architecture.
http://en.wikipedia.org/wiki/Sandy_Bridge#Desktop_platform
Now instead of having TWO processor cores, you can have FOUR with two REAL ones, and two VIRTUAL ones.
FOUR processors is what is essentially being said here.
TWO real ones, TWO virtual ones.
HOWEVER, your load that you are doing;...............
Internet searches...
Business/Office application, or program...
Game...
Video editing...........
Is not enough to use FOUR processor cores. So HT is not enabled at this time.
An aggressive, intensive new game, will click HT on; but who am I to know?
Program that you have multiple applications within it opened?
Running four or more programs?
Running two games at once?
Editing the lunar space program? lol!
Maybe THESE will kick HT on, dunno.
For additional questions please post in a Comment.
Regards,
joecoolvette
[Having HT with a processor that has TWO processor cores; is like having an alcohol burning dragster processor.
You don't use it to go to the supermarket ]
[Oh, and by the way;
NO, Intel Core i3 does NOT mean 3 processor cores.
There are TWO.
Processor Core:
Having two processor cores on ONE die chip; means there are TWO processors.
TWO processors contained in that one processor.
HT is kicked on you have FOUR processors ]
http://www.hardwaresecrets.com/article/535
http://www.hardwaresecrets.com/article/Inside-the-Intel-Sandy-Bridge-Microarchitecture/1161
http://www.hardwaresecrets.com/article/All-Core-i3-Models/951
[Yours is a 21xx Model ]
Posted on Jan 01, 2013
Laptop doesnt boot when multi core processing is enabled
By multi core I assume you mean when enabling all of the true processor cores. In your laptop's case it's a Dual Core processor which means there are only 2 phyiscal cores and does not contain HyperThreading Technology (HT Technology) which enables "Virtual processor cores"
Could be caused by a couple of things:
1. Your processor doesn't support multi-core processing which is a possibility given there is no HT technology for your CPU. In which case there is nothing to fix. Even though the BIOS may have this option. You can check to see if both cores are enabled when you have multi-core processing disabled; In windows right click on your taskbar and click on "Task Manager" Click on the performance tab. You will want to count the number of processor displays you see. Refer to this to see what I mean:
The reason I have 8 CPU displays is because I'm running an i7-3820 CPU which supports HT Technology; So I have 4 physical processors cores and 4 virtual processors cores (created by HT Technology architecture)
2. You are running Core2Duo CPU with dual physical processors and have disabled 1 of the 2 cores because your laptop won't boot. This sounds more like you need to update the BIOS on the motherboard or maybe a bad CPU might be the cause as well.
Hope this helps.
Sep 12, 2013 | Toshiba Satellite M505-S4945 PC Notebook
How do you enable hyperthreading on msi 661fm
You will need to enter the BIOS by hitting delete key during POST.
Then navigate to tab System settings.
Locate the Hyperthreading field name and set it to enable.
Save setttting and exit.
Please take the time to rate my expertise, by rating this solution, its the thumbs up on the top right hand side of this solution.
Thanks
Nov 02, 2010 | MSI 661FM (ms-6540gbb-010) Barebone
ASUS P5KPL-AM SE Motherboard no land card
Make sure you have it Enabled in the Bios (from page 2-17 of the user manual):
2.4.5 Onboard Devices Configuration
Onboard PCIE 10/100M LAN [Enabled]
Allows you to enable or disable the onboard LAN controller.
Configuration options: [Enabled] [Disabled]
LAN Option ROM [Disabled]
Allows you to enable or disable the boot ROM in the onboard LAN controller. This item
appears only when the Onboard LAN item is set to Enabled. Configuration options:
[Disabled] [Enabled]
Sep 08, 2010 | ASUS P5KPL-AM SE Motherboard
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
Intel(R) Pentium(R) 4 CPU 2.80GHz
The processor you are talking about is a single core processor capable of Hyper Threading. (HT).
When you allow hyperthreading in the BIOS, Windows will show 2 ghost processors in the device manager.
If you are authorized to acces the BIOS setup,,enter the setup and look for HT or hyperthreading. If you disable hyperthtreading in BIOS, you will only see one processor in device manager.
Besides, if it is a dual core the BIOS must know.
Look on the case of the computwr where the Windows logo apperas, you may find mentioned :With HT technology. It used to be a boasting/selling mantra.
Hope it helps.
Sep 08, 2009 | Computers & Internet
How do you turn on HyperThreading on a GX260?
hyperthreading must be supported by the processor. If you don't have that capability, it won't work.
Jun 09, 2009 | Dell OptiPlex GX260 PC Desktop
Intel P4 2.66GHz/512/533 is not working on MS9337C+.
#1. Does the CPU fan run if not then you may have a conductivity problem between fan and CPu. Did you use thermal paste or grease?
If fan is running follow directions below from my manual for MS9377C+ mainboard.
Go into the BIOS setup ,go to CPU setup, select proper voltage for you CPU. On Advanced setup page see if the hyperthreading function is revaeled. If so your CPU has this function. Set "Enabled " to test HT CPU function. If this doesn't work try "Disabling" the function. Good luck. I am about to attempt tp upgrade to a Prescott 3.0E which the box says this board supports. Sure hope so . Am running a 1.7 now.
umcds@sssnet.com
Apr 16, 2009 | Matsonic MS9337c Motherboard
How do I disable hyperthreading?
Hyperthreading is good. Why would you want to turn it off?
You can read about it here...Intel
Mar 20, 2009 | Gateway 508GE PC Desktop
Trying to turn off hyperthreading
You need to get into your BIOS. Go to CPU information. Highlight hyper-threading and enable or disable. Save and restart.
Dec 04, 2007 | E-Machines T3504 PC Desktop
Intel Motherboard Logo
124 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
