Question about De'Longhi En520.S Nespresso Lattissima Plus Coffee Maker, Silver
Descaling alert light flashing continuously even after descaling
Descaled after alert had shown,but alert keeps flashing. Then descaled with water only but light still flashing.
Red triangle will not stop flashing even after I descale
I have the Illy coffee maschine x7.1 and I'm trying to do the descaling (since the litle triangle sign is flashing), but power button doesn't start flashing after I push the coffee and steam button together (as indicated in the manual). Any suggestions what I should do, that the on/off button would start flashing?
Jan 25, 2014 | Illy Francis Francis X7.1 iperEspresso...
Red light flashing even though water tank is full
try to check the floating magnet inside of reservoir tank.
Nov 06, 2012 | Sunbeam Cafe EM6910
My Saeco Talea Giro plus is not even one month old and the descaling light was on. We have descaled twice thinking we did something wrong and the descaling light will not go off. During descaling the...
Did you often use the espresso machine for family or for business, when you often use the machine and you used water that is not filtered, you can assure it need to descale often.
Read carefully the manual and follow instruction. Did you descale it in the right amount of solution, how long and its duration?
If still persist ( the descaling light continue flashing ) then it has a defect in sensor. Since your machine is new, its under warranty. Call the dealer where you brought that and a service technician will send.
I hope I give you answer and solution idea for your unit problem.
Mar 29, 2011 | Saeco Talea Giro Espresso Machine
Water button orange light appear even after descaling
I had the same problem too.
Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off.
Hope this helps you too!
May 01, 2010 | Nespresso Lattissima 660.R
How do i get the red light to go off on my coffee maker i already descaled it
You have to ensure the descaling function runs completely to the end. Occasionally the water tank will be empty BEFORE the descaling program has finished, in which case you should refill it and let it continue descaling.
The light wiill automatically go off once the descaling program has been fully completed.
Mar 20, 2010 | Braun Tassimo Espresso Machine/Coffee...
Will not feed water and says descale
HI
Some machines shut down when they need to be descaled. Refer to your owners manual on descaling, then follow the instructions and your machine should go back to normal. These machines need to be descaled. Even the best water has mineral in it. Distilled water doesn't have minerals in it but makes the coffee taste different.
Nov 14, 2009 | Nespresso D300 Espresso Machine
How do |I get the red light to shut off? I have already descaled etc. Thank you
You have to ensure the descaling function runs completely to the end. Occasionally the water tank will empty BEFORE the descaling program has finished, in which case you should refill it and let it continue descaling.
Sep 25, 2009 | Braun Tassimo Coffee Maker
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
De'Longhi En520.S Nespresso Lattissima Plus Coffee Maker, Silver Logo
63 people viewed this question
Top De'Longhi Coffee Makers & Espresso Machines Experts
ray gallant
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a De'Longhi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
