top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
hi ; there's a problem in screen driver of your LCD, if you lost your receipt,that's bad luck. if you know how to disassemble the back case of the TV , you can try some RESETTING of connectors from LCD screen driver to display driver board
its only 50% chance to remove the line. thanks.....
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Had Sony KDF-E50A10 that had the same line problems after 16 months. Was fine at lunch time and when got home from work and turned it on, they were the lines. Want over $800 to fix it. Told me it was the B-Board assembly. Sony was no help. They have exteneded the warrenty on another part that works along with the B-Board but not just the B-Board itself, so probably not any more Sonys. I'm going with LCD now.
