Braemar airconditioner model LCB450-G flashing service code 2 and will not go into cool mode
  • Peter Hean Jan 03, 2013
    It was a sticky float. Thanks for your help
  • Greg Boxshall
    Greg Boxshall Dec 07, 2013
    How did you fix the sticky float? I have the same error code
3 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: Can't get airconditioner to work
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If wont work then there are some safety device that work or defective. Try counting the blink of your green light so that I can convert the error code.
Posted on Jan 08, 2009
  • 5 Answers
SOURCE: I have a Braemar LCB450-G
There are several possibilities, the drain valve is opening and closing, this causes water to fill the base, the float valve will not achieve the desired level so the fan will not start. This could be the drain valve actuator is U/S or the PC board. Have you tried to turn the main power off at the switch board for 1/2 hour?
Most occasions the service person will swap out all the units as they purchase it as a package. It is not cheap to replace these units.
Posted on Nov 26, 2010
Why isn't it heating?
Because its an air conditioner, not a heater?
May 03, 2015 | Heating & Cooling
I have a braemar model TE420 and when a press the on button on a confort control , the control is calling for Heat but the On & Wait signal is flashing and doesn' t start
Youtube doesn't show the Braemer specifically, but take a look at these and see if any of them work for you?
https://www.youtube.com/results?search_query=braemar+TE420+dishwasher+on+and+wait+light+flashing
Oct 04, 2014 | Dishwashers
What is a flashing 4
What brand is it. If its an evaporative cooler like breezair or braemar it means it is not draining the water. If so check the drain pipe and the drain valve
Sep 11, 2014 | Hunter Heating & Cooling
LG model LP1210BXR Water sprays out of air discharge while running in cool mode
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 28, 2011 | Heating & Cooling
My ac system has a model#44408 hunter thermistat and a trane heat pump. The system runs but does not change the temperature to cool the home to a comfortable temperature. is the problem in the thermistat...
You have refrigerant leak or the compressor has died...not a thermostat problem...
You will need to get a tech. to take a look at it.
Here is a tip about troubleshooting your airconditioner...
heatman101
Apr 20, 2011 | Heating & Cooling
The heat pump and fan stoped working the thermastat red light is flashing a code 2 blower fan and emergency heat working in the house.
heatman101
Mar 20, 2011 | Heating & Cooling
Our model is the ART30RLA ducted airconditioner and we are having problems with it. The problem is that it will not cool down, everything is running but it won't get cool. Could you please help us with...
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | Fujitsu Heating & Cooling
I have a Braemar LCB450-G evaporative cooler. There are two Diagnostic LED,s on the electrinics module,one red & one green. When the power is turned on at the module the red LED remains on & the...
Nov 22, 2010 | Heating & Cooling
Hi
Dec 25, 2008 | Heating & Cooling
ERROR CODE
Hi,Pls to shut - down the unit and try to power on ,may be its malfunction the control LCD.
THANX
Edgz
Mar 30, 2008 | Heating & Cooling
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
